1 - 1 of 1 Posts
The OEM Audio Plus Subaru BRZ Sound Solution.
We are proud to offer the OEM Audio Plus complete audio experience to the Subaru BRZ discerning drivers. O+ currently offers two sound solutions for the Subaru BRZ platform vehicles: The Reference and System Series. We not only guarantee the quality and reliability of every OEM Audio Plus sound system, we are confident you will not find a better sound experience for the money.
Quick Links:
oemaudioplus.com
Product Page on O+ Store
O+ on Instagram
O+ on Facebook
The Promise of OEM Audio Plus:
Each O+ Solution is designed from the ground up to deliver high fidelity sound reproduction without compromising the integrity of your vehicle (i.e. space, functionality, weight, performance or warranty).
What do we mean by “high fidelity sound?” We believe in sound reproduction accurate to the recording artist’s intent. Experience your music to fullest without any frequencies (High, Mids or Lows) misrepresented. Each solution is tuned specifically based on the acoustics, radio output and components of your vehicle.
The moment you plug in your O+ solution you will experience our signature sound (No tinkering necessary).
Features / Specifications:
-BRZ specific design and tuning | a sensory experience both visually and audibly.
-D.I.Y. Plug and play installation!
-No splicing, drilling of holes or customization of body panels for installation.
-Optimized for all vehicle factory radios and most aftermarket options
-Vehicle factory warranty remains completely intact when installed according to instructions.
-Product link: http://oemaudioplus.com/audio-systems
SIGNATURE TUNING
-Tuned exclusively for the vehicle acoustics of the BRZ
-Vehicle undergoes extensive acoustic measuring (using proprietary six microphone array)
-Every component (both stock and O+) is measured to determine the influence of the interior acoustics of the vehicle.
-Objective adjustments only go so far the final O+ sound is only achieved through extensive listening sessions amongst our sound engineers and O+ peers.
-Experience full dynamic sound reproduction from the front woofers (factory or O+) without the rattle commonly associated with the factory system.
AMPLIFICATION (2)
8 Channel 32-Bit DSP Power Amplifier
o360 Watts RMS (Continuous / @ 2-ohms)
oCirrus-Logic 32-Bit Digital Signal Processing
oReal-time system diagnosis for trouble-free operation
oMeets all OEM standards including AEC-Q100
Dedicated Subwoofer Amplifier
o180 Watts RMS (Continuous / @ 1-ohms)
oLow Voltage / Short Circuit Protection
-OEM grade: reliable performance & operation for the life of your vehicle.
-Programed O+ Signature Sound (Experience unmatched audio the moment you plug it in)
-Clean, unadulterated, undistorted power.
-Mounted to rear of Subwoofer System for minimal footprint and ease of installation. (No need to look for a spot to mount your Amp…)
1” FRONT TWEETER
-Designed specific to BRZ for both accurate fitment and superior acoustic reproduction.
-Dramatically enhances music’s clarity and detail
-OEM Grade Drop-In speaker replacement (Toyota/Subaru Spec factory connector).
-Silk soft dome
-4-ohms
-50W RMS (100 Peak)
-Sensitivity 91.8 dB (1 W,1M)
-Frequency Response: 3,000-20,000 Hz
-Built-in 6db/Oct. High Pass Filter
-Neodymium Magnet Structure
6.5” FRONT WOOFERS (REFERENCE SERIES)
-Engineered specific to BRZ for both accurate fitment and superior acoustic reproduction
-Designed to compliment our 1” Soft Dome Tweeter, The O+ 6.5” Woofer provides smooth full range sound reproduction.
-OEM Grade Drop-In speaker replacement (same mounting, same connector)
-Carbon Fiber cone material for optimal performance.
oCF is the ideal speaker cone material able to reproduce complex musical passages with a wide dynamic range without inducing distortion even at extreme volume levels.
-2-ohms
-50W RMS (100 Peak)
-Sensitivity 86.5 dB (1 W,1M)
-Frequency Response: 55-14,000 Hz
QUICK-SYNC WIRING HARNESS
-Connects seamlessly to factory harness and radio
-Constructed of genuine OEM connectors (sourced from Tyco, Sumitomo and Yazaki) to ensure perfect connection and maintain 100% signal integrity every time.
-OEM Fuse Holder Assembly featuring element proof butt-connectors and built-in solder
-Weighs under 4lbs / 1.8kg
SUBWOOFER SYSTEM
-8" Dual Voice-Coil Woofer (1.2 + 1.2 ohms impedance)
-Genuine Carbon Fiber Cone Woofer
-100W RMS (200 Peak)
-Sensitivity 88.9dB (1 W,1M)
-Frequency Response: 20 -1000 Hz
-BRZ Specific 14 Liter Sealed Fiberglass Enclosure
-Tailored minimalist design: All your vehicle's space, all your music's bass
-Weighing in at 20lbs / 9.07kg (entire assembly including 2 Amplifiers).
-Powered by Dual Amplification mounted to rear of enclosure
-Utilizes existing trunk liner fastener locations (no drilling necessary)
-Quick-Release knob for ease of installation (and/or removal)
Standard Enclosure Finish (Satin Black)
Factory Color Match Enclosure option (+$200 / 14 Day Lead-time)
Strut Bar-Ready Enclosure option ( 7 Day Lead-time)
* For Limited Time: As courtesy to Cusco Strut Bar owners this modification is available at no charge. / For other model Strut Bars please contact via PM for quote)
Compatibility:
• 2013-2014 Subaru BRZ
• 2013-2014 Subaru BRZ (RHD)
Price:
System 400+ Retail/MSRP: $1199 (+tax to California Residents)
Reference 400CF Retail/MSRP: $1499 (+tax to California Residents)
Where to buy:
-All authorized Toyota dealerships
-Direct through O+.com
- 6 Month Financing available through PayPal Bill Me Later (More Details)
1 - 1 of 1 Posts
