That's incorrect! ^^
UK spec cars are RHD exactly like the JDM, same goes for the Aussie spec cars which is what you might have.
You could also enter your VIN into one of those free online VIN decoders and see what comes up in the details...
That's incorrect! ^^From what i know UK spec redline is 7k and it is left hand drive.
Hope it helps! :tup:Vehicle Details;
Drive: Four Wheel Drive
Badge: WRX STi
Series: S
Body: Sedan
Release Year: 2004
No. Doors: 4
VIN Number: JF1GDBKH34H######
Seat Capacity: 5
Country of origin: JAPAN
Market: AUSTRALIA
Transmission: Manual
Number of Gears: 6
ANCAP Safety Rating
Overall Green Star Rating
Full Specifications;
Engine Location: Front
Configuration: Horizontal
Engine Cycle: 4 Stroke
Engine Type: Piston
Cylinders: 4
Cam: DOHC with VVT
Valves per Cylinder: 4
Fuel Delivery: Multi-Point Injection
Engine Code: EJ207T
Engine Size (cc): 1994
Compression Ratio: 8.0:1
Induction System: Turbo Intercooled
Power: 195kW @ 6000rpm (261 HP)
Torque: 343Nm @ 4000rpm (253 TQ)
Acceleration: 0-100Km/h (secs) 5.5
Fuel Type: Petrol - Premium ULP
Recommended RON Rating: 98
Fuel Tank Capacity (litres): 60
Fuel Urban (l/100km): 13.0
Fuel Extra Urban (l/100km) 9.0
Fuel Combined (l/100km) 11.5
Dimensions;
Kerb Weight (kg): 1470
Length (mm): 4415
Tare Mass (kg): 1437
Width (mm): 1740
Gross Vehicle Mass (kg): 1880
Height (mm): 1440
Towing Braked (kg): 900
Towing Not Braked (kg): 500
Track Front (mm): 1490
Track Rear (mm): 1495
Wheel Base (mm): 2525
They should be those little cute pink top feeds! :lol:Another quick question regarding the injectors. Do i have a side feed or top feed? I'm looking for a fuel system upgrade but i can't get much info on australia spec sti.
Thanks in advance.
