1 - 7 of 7 Posts
So I have an ecutek tune and a greddy profec ebc.. I like the greddy b/c I know how to use it. However I've been thinking about getting the Perrin BS so I can boost earlier and longer plus harder (kinda like a viagra ad huh? :D). Will that set up that I currently have plus the Perrin Boost Solenoid be okay with my current Flash??
Also if this is something that would benefit me where might I find the cheapest Perrin Boost Solenoid shipped?
I feel that the greddy solenoid is rather ****ty IMO.
Thanks!
-Jake.
pwn n00bs
the ebcs?
how much do you plan to boost? it won't be able to be tuned over like 21 or something because of the ecu...
if you want good boost, get a real controller such as txs dtec or apexi avc-r.
^ second that, currently boosting 21 at only a 85% WGDC. I have seen as much as 26 psi on the stocker.
can you pair the greddy profec boost controller with the perrin boost solenoid?
i personally can't see why you couldn't but you never know..
I suppose since the greddy has a wastegate control on it. You will need to decrease your WGDC a bunch and re-tune your boost to where it is suppose to be. Aftermarket EBCS use way less WGDC to achieve target boost. If you only have ecutek I would not recommend it. Raising boost and not retuning fuel and timing is a recipe for disaster
no i have ecutek tuned with my ebc to hit my target boost i was tuned for. i like piggy backing an ebc on ecutek so i can lower the boost a lil for daily driving and what not..
1 - 7 of 7 Posts
