1 - 3 of 3 Posts
Hey guys I just recently had a engine built to make power and tomorrow is my dyno day. From putting break in miles on it I noticed smoke coming from my hood scoop so I stopped and found out it was leaking oil. I since then re did the cam seals “all four” three different times, timing belt, oil pump, and the acvs. And it’s steal leaking not as bad but definitely still there. And I don’t want to not pass my pre dyno inspection. Any help,helps thank you
I just recently had a engine built . . .I noticed smoke coming from my hood scoop so I stopped and found out it was leaking oil. I since then re did the cam seals “all four” three different times, timing belt, oil pump, and the acvs. And it’s steal leaking not as bad but definitely still there.
Where is it leaking from?
1 - 3 of 3 Posts
