1 - 6 of 6 Posts
I just had my local shop complete an air pump delete on my 2012 STi. Car seems to run fine, but now it's giving me a knock sensor P0328 code. Feedback knock on the goes straight to -5.0 under 30%-40% throttle, DAM remains at 1.0 and fine knock learn is 0.0
Any ideas? Also, if someone could let me know the location of this sensor that would be super helpful.
Thanks!
curious did they reinstall the baro sensor? dunno if lack of baro sensor would lead to that code or not.
I asked him to leave the valve with the baro sensor intact, everything else is removed. I'm running a map with all of the air pump codes disabled
Not sure if this is significant or not, but the feedback knock goes to -5.0 and ONLY -5.0 like an on-off switch. It doesn't change from that value even at WOT.
I can feather the throttle lightly through the RPM range without getting a knock reading, but when the car gets under load thats when I see the knock.
1 - 6 of 6 Posts
