1 - 8 of 8 Posts
nice write up again...
let us know when you get the anti roll bars in.
also, the paragraph about the brake lines, you didnt mention if you were gonna go SS or some other "quick fix"...
FT,
would you think adding slotted rotors help prevent the OEM pads cooking onto the rotors, as you guys describe on the bottom of the OCT 13 test day?
Discussion Starter #8
Hello Leo,
Depending on the situation, they might; however, I would not bet on it. Slotted rotors help clean the pads more than allowing them to cool down with each pass of each slot. The front discs on the STi are huge, not just in diameter but also in thickness. The internally vented discs at that thickness should have been enough, if the stock pads were a little more heat resistant. I think the front rotors' size and and the weather being quite cold at VIR, the R4S pads held up. Otherwise, with the speeds that the STi achieves, we are not going to take a chance with anything less than track pads on track days, R4 or Hawk Blue.
For auto-x, R4S is plenty enough, and even the stock pads should do just fine.
1 - 8 of 8 Posts
