41 - 45 of 45 Posts
Discussion Starter #41
Did you ever check the hoses coming from the turbo and wastegate to the wastegate solenoid? Confirmed that the pill is in the right hose at the right location?
Go back to start. Do not collect $200.
did that already. its all good. pill is in place
and its for sure on the proper side of the T-fitting? Sorry if this sounds repetitive, but if the pill is on the wrong side, it will do exactly as you're describing.
Discussion Starter #43
ya pretty sure. checked 3 or 4 times. i will check again but ya pretty sure its on the right side
Discussion Starter #44
ok so i plugged in the ap and had it read the boost and in 4th gear i was gettin 18.3 plus. so it must be running just fine then? does that mean my boost gauge is off? is this ap accurate for sure or what?
Whats up guys im having a issue with my 2014 subaru sti for some reason I don't know y it doesnt boost past 4 lbs any ideas on what it could be when i accelerate it feels like it is struggling to pick up speed please help will really appreciate it 🙏
41 - 45 of 45 Posts
