1 - 15 of 15 Posts
Wasnt sure where to put it so sorry in advance mods!
Where do you guys get your oil filters from. I called my dealer and i cant make it out to them before they close today, so can i get one from like pep boys or something?
thanks
OT stealth mod
I use a mobil one filter :notsure:
available from any autoparts store.
I use the Purolator Pure One PL14610 from Autozone, Advance Auto, Walmart, etc. WolfPlayer has done a ton of research on this and rated this one as second only to the OEM filter.
Edit: Moved this to the Service forum.
Discussion Starter · #4 ·
:lol: Del i like how you have to edit to say you didn't do something wrong.
k thanks guys and thanks for moving it klaymon.
i think ill pick up the purolator 14610L
Fuc***#@$^. I've been using PL14612? AM I using the wrong part number?
No, you can use either one. I can't remember which, but one is slightly larger than the other, but they both work fine. Carry on. If you really want to get into the nitty gritty of it, look here:
http://www.bescaredracing.com/sti/oil/filters/sti_oil_filters.xls
Here's the thread that started it all:
http://www.iwsti.com/forums/showthread.php?t=16252&highlight=oil+filter
Edit: The 14610 is larger than the 14612, but they both work fine.
Well that helps . Scared me a bit there i thought that i was using the wrong one.:lol:
And this is why i like IWSTI:bow: !
Drive True
I thought purolators are just re-labeled Fram Filters? I heard Bosch premium filters are good ones to use. I believe the 3310 is the one you want, I imagine the STi uses the same one as the WRX.
does anyone have an opinion on the k&n oil filters, I put one on the last time because I thought that the 1" nut on top for removal would be nice. Hopefully they do a great job filtering too!
the nut is nice for removing the filter, but really you should be able to hand untighten your filter, I have many times
its just about how much dough you want to spend, like the Mobil 1 filter
1 - 15 of 15 Posts
