1 - 6 of 6 Posts
Before Purchase - 117k Miles - was up for sale because it had jumped timing, or so thats what the prognosis was
63271
The teardown! Cyl 4 lost a rod bearing, heads were super duper shot, case in general was very... gunky?
63273
Little whiteboard action; tagging and bagging, and keeping the parts list updated when finding xyz was 'broke/missing'
63274
Cold tanked the halves to be sent off for machining
63275
63276
Bolt cleanup to make re-assembly go smoother
63277
Barb clip on the TB - removing the TB Coolant loop.
63278
OEM vs KillerB, huge upgrade!!!
63279
Fresh Heads (No port work, just stocker replacement w25s with GSC seals, oem ones ran on the spun bearing too long and all the journals were past tolerance)
Discussion Starter · #2 ·
63280
New rods
63281
63282
Previous owner had 225s stretched on the 8.5 bbs rims, swapped them out for some lightly used 255 super sports
63283
New Meats
63284
63285
Still had the stock suspension, was a little tired, found a good deal on a low mile VA Chassis suspension for now. Just bent the front brackets for the holder and ran a m6 ss nut+bolt combo in the holder.
63286
Case halves returned!
63287
Cam Gears all returned, exhaust side was rebuilt, intake side are new (Old ones were damaged beyond repair)
63288
Discussion Starter · #4 ·
63299
Both OEM ground straps were shot (Copper units) ended up doing a modified version of the 'BIG 3'
63300
63301
0WG NEG leads to a 1-4 4AWG Output, mounted to the frame rail with a M6 Bolt
Discussion Starter · #6 ·
63305
Wiring up WBO2 and Oil Pressure Gauges (WBO2 is using 5v signal for AP logging)
63306
63307
Pretty close to being pinned up, got compression, spark, fuel, and good air, gotta go through and clean up all the ancillary stuff.
Also waiting on seals for diff / axles / and I overcooked the rear main so its got a minor oil leak out of the bellhousing that ill drop the trans and replace the rear main before it goes on a maiden ring break in voyage.
We had to plug the passenger side head for the oil feed design change, oops.
Fix issues with the oil pressure sensor.
Also the coolant temp sensor (from the gauge pods you can see) is done for. ECU reading -40; cluster reads max heat, fan stays on all the time. New one ordered as well.
1 - 6 of 6 Posts
