1 - 6 of 6 Posts
i/c spray and factory fog switch
Hi,
I have the Boston NX57's 5.25's for the back of my STi. I can't get them to fit. When i use the spacer i can't get the door panel on. Any solutions????
Thanks
Shane
I have MB Quart 5.25's in there and they are mounted inside the door (IOW inside the hole)... the rear windows don't roll down all the way and therefore don't have the clearance issues the fronts do. They only have a depth issue with the panel, requiring them to be mounted inside.
You will need some little metal clips with threaded holes to put on your speaker mounting bracket so you will have something to screw into when you put your screws through the door panel. And first you will need to put the speaker on the outside and drill your holes so you know where they need to be located.
1 - 6 of 6 Posts
