1 - 2 of 2 Posts
· Vendor
Rectangle Sky Font Magenta Window
Presenting the AWE Touring and Track Edition Catback Exhausts for the VB WRX:
Overview:
  • 3” catback configurations
  • Features a slip-fit inlet adapter for perfect factory downpipe fitment while leaving an open 3” connection
  • Deep, aggressive BOXER® tone
  • Available as Touring or Track Edition Catback Exhausts
  • Touring Edition features AWE’s patented drone-canceling solution, 180 Technology®
  • Max gains of 7 hp and 4 ft-lbs of torque at the wheels
  • 4” double-walled, slash-cut tips available in chrome silver or diamond black
  • Handcrafted from CNC mandrel-bent, U.S.-sourced .065” wall T304L stainless steel
  • 50-state emissions legal
  • Proudly engineered, designed, and manufactured in-house at AWE, in the USA
  • Direct bolt-on for factory-like simplicity
  • Conversion Kits available to easily switch between editions
  • Less is more: clean, straight-through design maximizes flow
  • Perfect fitment, guaranteed
  • AWE No Check Engine Light Guarantee
  • Lifetime warranty
Touring Edition Exhaust:
A direct bolt-on, straight-through design with a modular inlet featuring an adapter to accommodate the factory downpipe perfectly while leaving an open 3” connection.
The Touring Edition allows the WRX the rumble without rasp or in-cabin drone, while introducing intoxicating crackles when shifting, thanks to AWE’s proprietary drone-canceling solution, 180 Technology®. The Touring Edition is all about optimal performance and tone out of the 2.4T while keeping it comfortable within the cabin.
Perfect tone, compliments of AWE 180 Technology®.
As exhaust gases exit the FA24 engine and flow into an AWE 180 Technology® equipped resonator, they pass through strategically located ports, and into reflection chambers. Sound waves, carried by these exhaust gasses, bounce off the walls of the reflection chambers. By controlling the size and location of the ports and the chambers, we also control when the sound waves exit the chambers. The specific timing of when the reflected sound waves rejoin the main exhaust flow creates a one-hundred-and-eighty-degree out-of-phase sound wave that cancels out problematic frequencies. More on AWE 180 Technology® in the tab above.
Track Edition Exhaust:
For those looking to take it to 11, and leave it there, go Track.
The Track Edition retains all of the precision engineering from the Touring Edition including the modular 3” inlet and adapter, minus the AWE’s 180 Technology®. The result? Unfiltered BOXER® rumble both in and out of the cabin.
This version is known to get rowdy and may be too much for many. For that reason, this particular version cannot be returned due to sound preference. Prepare yourself.
Tip Options:
All tip options include the AWE logo and double-walling to ensure a mirror finish even under hard usage. All tips are individually adjustable, allowing depth into the bumper to be set according to personal taste.
Conversion Kits:
We made it easy to convert from a Track Edition to a Touring Edition, or vice versa if you decide at a later date to turn it up or turn it down.
Performance Specs:
1 - 2 of 2 Posts
