1 - 20 of 36 Posts
It Begins
2013 Dark Grey Metallic WRX STI
Goal: A daily driver with a setup that prepares for greater things to come. My DD goal is around 350whp without sacrificing too much reliability. The car will then be garaged and worked on more heavily.
- Chris S.
Mod List
Not Purchased
Purchased
Installed
Engine:
  • GrimmSpeed Lightweight Pulley
  • IAG TGV Delete
Fueling:
  • DeatschWerks 265 LPH Compact In-Tank Fuel Pump
  • AEM 320
  • ID 1050x
  • SUBARU FLEX FUEL ETHANOL SENSOR KIT - STI 2008-2019
Turbo/Intercooling/Misc:
  • Cobb Intake w/ Air Box
  • AEM Water / Methanol Injection Kit V2
  • AEM V2 5 Gal Tank Kit W/ Conductive Fluid Level Sensor
  • Perrin FMIC (Red)
  • GrimmSpeed Boost Control Solenoid
  • GrimmSpeed AOS
  • Perrin Turbo Inlet (Red)
EMS:
  • CCobb Accessport
  • Pro Tune
Exhaust:
  • Perrin Catback Exhaust
  • Perrin Turbo Blanket
  • Invidia Downpipe
  • Killer B Holy Header EL
Driveline:
  • Cobb Adjustable Short Shifter
Exterior:
  • Rally Armor Mud Flaps
Suspension/Bracing:
Brakes:
Interior:
  • HKS Turbo Timer (Red Digits)
  • HKS Turbo Timer Harness
  • ATI Center Gauge Pod
  • ProSport 52mm Boost Gauge
  • ProSport 52mm Oil Pressure Gauge
  • ProSport 52mm Air Fuel Ratio Gauge
Discussion Starter #4 (Edited)
Re: 2013 Dark Grey STI - Hatchback
Cobb Access Port V3 was purchased on 8/30 with free next day shipping promotion from Got Boost Inc. Lets see if it actually comes today.
A call was placed in yesterday to them in addition, because I was curious as to why the order wasn't showing that it had been shipped and there was no response...
Access port is in!
Discussion Starter #5 (Edited)
Hi Everyone,
I haven't been on in a while, but the work hasn't stopped :)
Cobb Shift Knob
Invidia Downpipe
Pro Tune - Thanks to Ray at TurboTek Tuning and Fast of West Chester
Perrin Thermal Blanket
Discussion Starter #18
Re: Family Car Taking Roids (2013 Dark Grey STI - Hatchback)
Hi Everyone,
Any suggestions on modifications that that would provide some HP/TQ gains that wouldn't blow my current tune? I don't believe there is much out there.
Any feedback regarding a build path would be greatly appreciated as well. I would like to start doing my research while I continue to enjoy the car as is. Also, the wife has be on a bit of a budget right now :(
Thanks,
Chris
Hi Everyone,
Thanks,
Chris
Basically everything at this point is going to require a tune. I think EL headers and a TMIC are probably your next choice. You are probably stuck there until you open up the block and do some internal work.
Discussion Starter #20 (Edited)
Any opinions on UEL Headers and TMIC?
UEL Headers - I want to keep the the boxer rumble, so I am leaning towards UEL.
TMIC - Is the STI scoop big enough? I don't think I want or need a FMIC because of my HP goals, but I welcome additional feedback.
Side note: Any reason you didn't mention larger fuel injectors? Was it because of me trying to avoid having to re-tune?
1 - 20 of 36 Posts
