21 - 40 of 58 Posts
Discussion Starter #25
Re: No crust - 2011 pbp
Long story short.... ground my own cam buckets to fit properly after wrong order.
Tomorrow I’ll seal up the engine, do the timing and it’ll be ready for drop in.
I’ll be running the gates Kevlar/racing timing belt kit. Everything on it is stamped Japan - no worries about failed pieces.
From whom did you order the gates kit from? I've heard conflicting information when it come to what parts you get. People have received a lot of Chinese junk.
Discussion Starter #27
I've had this kit for a while so it could've been before they changed over. However, some people have stated that the kevlar/racing timing belt kit still uses Koyo Japan parts.
Discussion Starter #30
man, i wish i could knock down my home remodel projects like youre doing this engine.
fine work sir.
:usa:
Thanks man :lol:
Little motivation goes a long way. I haven’t done any work in a long time and I wanted to crank this out. No time for feelings and thinking, just bang it out :lol:
Discussion Starter #33
Car will be picked up tomorrow from the shop for some final assembly!
Remaining list:
- wiring harness
- timing
- Timing covers
- alternator/PS installed
- crank pulley and belts
- hook up heater core
- install rad plus hoses
- hook up PCV plumbing
- fuel lines (body to rails)
- Oil feed and drain for turbo
- coolant for turbo
- IAG AOS install
- transmission mount
- hook up and bleed the hydraulic throw out bearing lines
- FMIC and piping
21 - 40 of 58 Posts
