These are off my 2021 WRX STi with less that 9,500 miles. This OEM Subaru wheel was new for the 2018 model year of the Subaru WRX STI. The 19 x 8.5" size looks terrific and fills out the wheel wells of the latest body style nicely, but it can also fit other 5x114 bolt-pattern Subarus. Note that although it fits fine over the 2018+ STI six-piston front Brembos, it does NOT fit over older four-piston STI Brembo brakes without a 5mm spacer.
Includes the factory center caps. Included TPMS sensors will need to be programmed to work with your specific vehicle. The included tires are the factory 245/35/19 Yokohama Advan Sport V105. Tires are in good usable condition with no punctures or uneven wear. Each tire has approximately 8/32" tread depth remaining. Tires have a 121 DOT production date with no major dry rotting and cracking in the rubber. In good physical condition with no major cracks or bends. Each wheel has been fully tested @ DTC on their wheel balancing machine with no visible wobbles or bends. I am willing to deliver in a 200 mile area of Santa Fe for $100. extra.
