Year:2008
Make:Subaru
Model:Other
Mileage:188598 M
Transmission:Manual
Engine:4cyl turbo
Trim:N/A
Contact Info: DM me
Pictures: 2008 STI OBP
This is a one-owner car. No one ever has smoked in the car. The car never has been launched off the line and always was driven moderately.
Blemishes include rock chips on the front fascia and hood and small dents in the roof with some rust. The left-rear rocker in front of the wheel and the left-rear door have been repaired due to a collision with a low-speed pylon. The rubber protector has worn off of the rear hatch open button. The engine bay insulation has worn away. The Lamin-X tail light overlays have faded. There is an NMO mount on the roof behind the antenna. The left bolster on the driver's seat exhibits significant wear, and the tonneau has tears on both the left and right sides.
Major mechanicals replaced:
  • Long block, due to #4 piston failure
  • Turbo, due to alleged fracturing
  • Timing belt
  • Steering pump
  • Steering rack, due to leak
It also has a new battery as of 9/2022.
The engine runs well. Power and boost are as expected. The 6-speed transmission shifts smoothly. All recalls have been completed. Synthetic oil always has been used. Service history is available. Everything on the car works properly except for right front window switch and door lock switch, which need to be replaced.
This car has no internal engine mods and was modified very conservatively and corners noticeably more flatly than stock. Please refer to my build thread (gvfs' 2008 OBP GRB), but here is a list of mods separated by category:
Engine:
Cobb AccessPort Stage 2 + AEM
AEM Intake
Harman Motive Turboback
Perrin Crankshaft Pulley
Drivetrain and Suspension Mounts/Bushings:
Group N engine mounts (left D1010FE120, right D1010FE110)
Group N transmission mount (ST410224S000/D1010FE000)
Whiteline rear diff bushing inserts
Whiteline rear differential forward mount bushing kit (KDT905)
Whiteline 24mm FSB (BSF39XZ), 24mm RSB (BSR49XXZ), and D-bracket braces (KBR15)
Whiteline front lower control arm bushings
Braking System:
Grimmspeed stiffening brace at master cylinder
Exterior:
Rear fenders rolled and pulled to accommodate 275s
Subaru OEM sport grille
OEM foglight kit
LightWerkz Angel Eyes in the headlights
Hella Supertones
Interior:
Damd flat-bottom steering wheel with red stitching
JDM Subaru oil temp and boost gauge kit
Pioneer AVH-4100NEX head unit
Backup camera
Rubber mats and rear tray, OEM standard carpet floor mats included
JDM start button and surround (83031AG001, 83002FG060JM) - Never connected
Wheels/Tires:
-Winter: 18"X8" 5-114 ET45 Sparco Podios with 245/40R-18 Pirelli Winter Sottozero
-Summer: 18"x9.5" +45 Enkei PF01s with 275/35 Falken 452s (worn)
-OEM 5-spokes with badly-chipped paint
