New Volk Racing RE30 Sizing!
13K views 66 replies 23 participants last post by  BriTtO
#1 · (Edited)
Figured I'd let you all know that there will be some new Volk Racing RE30 sizing coming out here in the near future.
18x9 +50mm!!
ooh it's going to be pretty.
All these 2008 STi have no reason to not get this size wheel.
It's going to fit like a charm.
this 18x9 +50mm is to the GR what the 18x8.5 +52mm is to the GD
here's some more info on it if you're curious :)
New Volk Racing RE30 sizing!! Must Read for 2008 STi. » t3h_Clap’s Wheel33tist Blog
I'm working closely with a few select Vendors to see when these will first be hitting our shores.
Thoughts?
-t3h_Clap
#4 ·
it may work depending on your suspension setup.
it would work on a car still on stock struts and springs.
the issue would be when lowering the car and fender clearance or when upgrading to coilovers the clearance with the larger strut housings/spring perches.
It would be a good option for someone who wants to go wide wheel/tire but stick to stock height or have a stiff/high enough spring combo to not have fender issues.
#5 ·
:D i want!
so is there a release date anywhere?
#6 ·
I'm working on it.
#8 ·
they make higher offsets in the same width/diameter for the guys looking for a more aggressive setup on the GD chassis.
#10 ·
those are the 18x10.5s
#11 ·
wait so these will fit the 06-07 too right? if so is this the biggest offset wheel that fits?
#13 ·
what's your suspension?
#12 ·
you will be limited in tire widths.
on the GD, the offset is high enough where you run the risk of rubbing with anything wider than 245.
and even with this you need the right suspension, all 9" wheels require the correct suspension.
#15 ·
it depends on the tire you're hoping to run.
are you only considered about ride height?
#17 ·
how about 18x9.5 +47mm :D
this size RE30 is available and listed to clear brembos. :)
it's the first thing i'd buy for my 08 STi. (if i were to get one).
#19 ·
not on an 08.
08s have an insane amount of room.
alot of guys are running 18x9.5 +45mm and 275s.
so the 18x9.5 +47mm and a 265 would work with very little issues (maybe some minor fender rolling as the 08 can benefit alot from that).
#21 ·
it wouldn't not be an easy fitment and it would come down to which suspension you selected.
how much camber you have at the strut and what size tire.
in other words, there are better options.
the 18x9.5 +40mm is a better choice for the MY05-MY07 cars. the RE30s in that size clear brembos as well.
alot of the 9.5" info can be found on my blog as well.
Aggressive STI fitment version 9.5″ » t3h_Clap’s Wheel33tist Blog
#23 ·
it's the only reason to get an 08 kicken wheel selection :lol:
#28 ·
the S1 is the weak looking face.
S2 is concave it just isn't S3 or L2.
then again all RE30s look bad ass.
#30 ·
That size is just fine. YOu could run a 245, or maybe even a 255 tire without any problems.
