Drove my 2016 STI with 63K miles to a reputable tuner shop and had a compression test done. Pass mods by previous owner was a cat back self weld job and a protune by a well known Subbie tuner. They came back with a sheet that said all 4 cylinders were at 115psi. According to them the normal range should be around 130ish and that at least they are all on the same psi which is good. They mention it is not too low but it is lower than desirable. They said is hard to pin point why is that low and the only sure way would be to tear it up and inspect for wear or damage. I just purchased this vehicle and I am afraid this lowish compression psi might be a sign of worse things to come. I understand the pattern across all 4 is good but it seems much lower than most I found while doing a search and reading. Any past experiences or feedback would be much appreciated.
-Also is it normal to have all cylinders with the exact same PSI??
