1 - 8 of 8 Posts
Vendor
Ohhhhh snap.
What did ATi just release today?!
Single gauge 60mm mount, that is what!
This 60mm single gauge pod is the perfect solution for the person wanting to install a single gauge in their car. It fits on the dash to the left of the cluster hood and has the gauge wires run down the defrost vent.
The pod has a smooth black finish and is attached with double sided tape.
***This pod only fits LHD cars***
  • Attachment Method: Double Sided Tape
  • Gauge Size: 60mm
  • Material: Plastic
  • Pod Color: Black
Kirill
RallySportDirect.com
RSD,
How does wiring match up to this? Do you have to drill a hole into your current guage cluster to be able to feed through? I always wondered about this.
Sent from my iPad using Tapatalk HD
Vendor
Discussion Starter #4
Looks perfect! Will be purchasing soon. Any suggestions on a 60mm boost gauge?
DEFI is the way to go, they match the OEM gauges PERFECT and are super easy and clean to install.
RSD,
There is a opening on the side of the pod that you can run the wires. However most people opt to drill a small hole in the hood to allow for a much cleaner install.
Kirill
1 - 8 of 8 Posts
