Hello,
I rarely post here but I'm in a bind here and looking for some help.
My car is 2007 Sti.
2 years ago I had ring land failure on the stock pistons. So I had a new engine built. Due to Covid and lock downs it took till this year to get it installed.
I have been driving it with the "break in tune" for about a month. (400+ miles so far.)
Here are the symptoms:
Idle is horrible when I start it. It takes a full 2 minutes for it to stabilize. Once it does it's good. I can then drive it for 20-30 minutes and it's a dream. No issues.
After that time, if I come to a stop, the engine wants to die. It'll go crazy trying to find an idle. At least half the time the engine will just die. Quite often as I'm coming up to a stop sign or light I'll see the red light, drop it in neutral and coast to the light. By the time I get there, the engine has died.
The tuner who gave me the break in tune sent me an updated tune and it helped. For awhile. But now it's back and worse then before. IOW the problem seems to be mechanical, not the tune.
The tuner will no longer respond to my emails.
The guy who did the work was supposed to be a Subaru guru. He had 20 Subies in his shop when I meet him. He has 2 employees. Seemed like a knowledgeable guy.
But when I got the car back initially I found:
#1. Fuel pressure sensor (aftermarket) was installed in the return line, not the pressure line. (I have fixed it now.)
#2. The OEM EBC was plumbed backwards. When I informed him of this he sent me the instructions for some aftermarket EBC. I said that's not what I have and he said 'Oh, I thought you did." The boost side went to atomsphere and vice versa. I took pictures and video showing how it was hooked up wrong. I read dozens of forums and article to confirm, it was 100% backwards. (I have fixed it now.)
#3. The clutch shield was left off. No reason why.
#4. The air pump was not hooked up. He said there was no reason to hook it back up as it has "no where to go." I don't know what that means. That I can tell there are lines from it going someplace under the TMIC but I have no idea where or where they are supposed to go.
#5. The rear O2 sensor wire was not tied up, it was literally laying on the 2nd cat.
#6. There were various other scratches on the car that were not there when I dropped it off. Some serious.
#7. There was about 1/2 cup of oil on the top of the engine. I removed the TMIC and cleaned it up, it has not come back. The oil level has remained good. The guy said they "might have spilled some when filling it." (But clearly to lazy to pull the TMIC to clean it.)
And there are more items but you get the idea.
So clearly I picked the wrong shop. I'm NOT naming anyone at this point until I know exactly what the underlying issue is.
So here is my way of thinking: Whatever it is, is temp related. Once this dying starts there is no going back. I can reset the ECO and it still does it. The only way to resolve it is to let the car sit overnight and go totally cold again.
I have no faith in the guy who did the work. ZERO. I do not want to take it back to him because I don't believe he knows what he is doing.
The tuner will not respond to my emails. I know he's busy and he already has helped me so much I understand his position.
I'm hoping someone can offer some advice as to what this could be so maybe I can fix it myself.
The only CEL I get is P0442. But I had this code since before the old engine retired itself. I have checked all the obvious things (fuel cap, cracks in hoses, etc) Everything visibly looks good. And I had it with the old engine and the new engine. Some of the items off the old engine were reused on the new so maybe it's there, but that I can tell it looks okay. One thing I am not sure of is are all the hoses routed correctly. Since he got the EBC and fuel pressure sensor wrong, that is my primary concern. I know old domestic cars very well but these new ones I'm pretty ignorant of. But I am willing to learn.
P0442 is the only CEL I get. I can clear it and it fixes nothing. (Cobb AP). No other codes. And the car acts up the same way whether I get the code or not.
This has to be some valve that opens up when the car is well into operating temps. That is causing a vacuum leak.
Also monitoring the knock, it shows pulling timing from time to time. I have seen as much as -11. I'm running 91 (Shell Premium, that's all I have were I live) and that is what the tune is for. I have even added Boostane to get it to 94 Octane and even 97 and it's made no difference.
On the highway it runs well. Smooth as silk but at idle, backing into the garage, maneuvering thru a shopping parking lot is a nightmare. It'll die 3-4 times before I can get out.
And it's getting worse. Tonight the engine sounded like it was running on 3 cylinders. Very lumpy idle, almost trying to die and then save itself and then repeating over and over.
The only other tidbit I can offer is the oil pressure is all over the place at idle. 20psi, 5, 1, 15, 5, 7, 15, 3, 20, etc.. At RPM it's fine. 40-50 psi pretty steady. I suspect that is an effect of the idle issue, not the other way around.
So if you have some time and insight I'd love to hear it. If you have photos of that EVAP system at the engine, and were all those lines are supposed to go that would be great. Anything else? I'm all ears.
Thank you.
My car is 2007 Sti.
Thank you.
