Yeah has been but I've finally taken the time to identify it lollooks like its been leaking a while
Get an after market billet one ... It's called a Pitch Stop Mount:How about this snapped plastic rod thingy? I watched a video on it but can't seem to recall it's name...thanks View attachment 68221
I've not messed with it, personally, but check to see if it has an o-ring to seat to the engine. Your switch may not be busted but the o-ring may be. $2-3 fix if so. If the oil pressure switch doesn't have this, definitely replace and thoroughly clean that area before you put a new one on.Yeah has been but I've finally taken the time to identify it lol
I believe they have little teflon seals on them, but I could be mistaken. But good point otherwise.I've not messed with it, personally, but check to see if it has an o-ring to seat to the engine. Your switch may not be busted but the o-ring may be. $2-3 fix if so. If the oil pressure switch doesn't have this, definitely replace and thoroughly clean that area before you put a new one on.
The oil leak is the oil pressure sensor. The other piece is called a "pitch stop mount" in the aftermarket world. If you're going to replace it, upgrade with Group N.
I went with the perrin...thanks for the help !Get an after market billet one ... It's called a Pitch Stop Mount:
1. IAG Street Series Pitch Stop Mount For 2002-22 Subaru WRX, 04-21 STI, 04-13 FXT, 05-09 LGT (Black Finish)
2. GrimmSpeed Pitch Stop Mount
3. https://www.perrin.com/shop/drivetrain/pitch-stop-mount
Take your pick.
This is what the piece looks like. Only like $12 CAD so I'll replace it anyway. Not sure if it has an O-ring or not but I'll find out soon.I've not messed with it, personally, but check to see if it has an o-ring to seat to the engine. Your switch may not be busted but the o-ring may be. $2-3 fix if so. If the oil pressure switch doesn't have this, definitely replace and thoroughly clean that area before you put a new one on.
