1 - 5 of 5 Posts
Discussion Starter · #2 ·
Btw, just went dealer they said is fine and all four tires are 9/32. And they find another nails on that tire too. 4 ON THE SAME TIRE.
Discussion Starter · #4 ·
Patch and plug, not just plug. As long as they are within the repairable zone, you are fine.
I think the one cause leaking air is in repair zone, and one on the shoulder but it’s not leaking. Dealer just pulled out and leave the hole there, and so as other 2
It is possible that the other two weren't long enough and did not penetrate the tire. I will assume that the dealership checked them correctly either by submerging it in water or use soapy water to check for leaks. I am however, surprised that they only did the plug and not both patch and plug. I would either have them re-do it or go to a tire shop and ask them to patch and plug.
1 - 5 of 5 Posts
