381 - 400 of 631 Posts
Discussion Starter #384 (Edited)
Re: My 2015-2017 Subaru Journal
My first attempt in pressing out bushings on the STi:
My cordless impact driver battery died, forgot to charge it:
Manual turning is my next option:
Now for pressing the SuperPro Bushings:
My stock rear diff bracket and my extra rear diff bracket with superpro bushings:
I can't imagine that is actually supporting anything.
That brace supports the stamped section welded to the subframe which the RSB mounts to.
That mount can be nearly flexed by hand. Adding some lateral support there couldn't be a bad thing.
Hey aj, is that a Harbor freight bushing press? I've considered picking one up...
Discussion Starter #388
Thanks for the explanation on how the rsb brace works.
Got these bushing press from ebay. It is called Universal Press and Pull Sleeve kit.
Discussion Starter #389
Went back to my stock shifter trim, vinyl wrapped the silver trim and added JPM coachworks leather shifter boot:
I am still not seeing it provide any real support, especially on how the bracket gets loaded. Lots of braces out there don't really do much, but people like installing them, especially the bolt in parts.
Discussion Starter #391
555 miles! "555" Paying tribute to the Subaru World Rally Team 1993-2003
Just arrived:
JDM MFD Hood with red stitching:
Tried to paint them but did not came out well:
Instead, vinyl wrapped it with gloss black 1080 film:
[/URL][/URL]
Curious, how is the black Vinyl holding up on the vents? I have been itching to do this!!!
Discussion Starter #395 (Edited)
LOL Matt ^^
Here you go:
More SuperPro Bushings just arrived: Special Thanks again to [email protected] for best pricing-fast shipping on my STi suspension goodies!
PITA bushing removal again...
Special Thanks to subi114(Chris) for an awesome deal on the rear trailing arms and rear lower control arms!
Greased up the bushings and pressed in...
All done.
Installation time:
Discussion Starter #396
Moved the Traction control button to the left where the blank cap is located:
(Thanks to Blackalicious for asking me for a DIY mod, totally forgot to do this on day two)
Disconnect all wire connectors from the switches:
Trac button and blank cap, side tab on trac button is bigger:
Trim the tab opening to fit the trac button switch:
Re-install the trac button switch the modified tab location and push in the blank cap to the right opening:
Much better access to trac button switch :
Discussion Starter #397
Stocking up my JDM oil filters for the Red Devil :devil:
Love the build, all the great information. A few questions:
1. On your Launch Edition, you had quite a few Cusco suspension bracing pieces. You have gone with Beatrush on the Red Devil. Why the change? Dissatisfied with the Cusco? Just wanted something new? Some other reason? Also, any comparisons between the two, specifically the strut tower braces?
2. Also noticed on the Launch Edition you had a Cusco catch can or an AOS. Do you have plans to move to the Red Devil? Why or why not?
3. Are the STi Sport oil filters magnetic like the Prova ones?
Discussion Starter #399
Thanks again!
1. Nothing wrong with my cusco suspension parts, they are awesome. Just a change of set-up on my red one.
2. Not planning on installing the cusco catch can for this current build. Keeping the engine stock for now.
3. The STi oil filters are not magnetic. The filter media is wire mesh reinforced to handle higher temperature/load.
Discussion Starter #400
My first 1000 miles on the odometer...
More goodies...
SuperPro Rear Sway bar Link:
STi Group-N Transmission mount:
SuperPro GearBox Cross Member Bushings:
