1 - 13 of 13 Posts
Discussion Starter · #6 ·
Thanks for the compliments. :)
That boost gauge is not the stock one. It is a replacement 45mm Omori mechanical boost gauge. The stock one lights up white, and reads in mpa. This one has a red needle, red backlight, reads in psi, and fits easily in the stock boost gauge spot. It does block the ambient temperature readout, however (but it's not like I stare at that anyway).
viking067: The strut tower brace is a replica STi bar. It fits easily once you remove the a/c bracket. You can find it from a variety of online vendors. Tires are the stock RE070s.
-Mike-
Very nice! Hey Mike are those the mats from cc-b? If not then where did you pick them up and how do you like them? Same question about your dead pedal.
Discussion Starter · #9 ·
Yes, those are the cc-b.com mats. The material of the mats looks of higher quality/durability than the standard WRX mats (the material is more like the blue carpeting in the STi). The dead pedal is the one autospeedperformance.com sells.
-Mike-
1 - 13 of 13 Posts
