Performance - VERY FIRST MODS (engine block):
GSC Power
- Intake & Exhaust Valve Guides (Stopper Style)
- Division Single Beehive Valve Springs & Titanium Retainers
HKS
- Fine Tuning V Belt
IAG
- Competition Series EJ Belt Tensioner
King Engine
- Main, Rod, Thrust Bearings
LIC Motorsports
- Alumninum Cylinder Head Plugs
Manley
- 83mm Stroker Crankshaft
- Race Flo Intake Valves
PERRIN
- Lightweight Crank Pulley
Subaru OEM:
- 2.5L Oil Pump
Tomei
- 1010mm x 07mm Head Gaskets
- Poncam Camshafts
- Timing Belt
- Timing Belt Guide
Torque Solution
- Timing Belt Guide
- Cylinder 4 Coolant Mod
Wiseco
- 99.5 Forged Pistons
- 130.5mm Boostline Piston Rods
Performance - THE MAIN COURSE (engine bay, transmission,handling) :
Aeromotive
- Side Feed Fuel Rail System bundle (Lines, Rails, O-Rings)
Beatrush:
- Shaft Mount Bushings
Boomba:
- DBW Throttle Body
COBB:
- Stage 2 Bundle (Accessport, Intake, Intake Airbox, Intake MAF Hose, Turbo Heat Shield, 3" Downpipe)
- High Flow Filter
- Pitch Stop Mount
- Front & Rear Shifter Bushings
- AOS
- Throttle Body Hose
- 4 BAR MAP Sensor Kit
- Reverse Lockout Pull
Cusco:
- Sports Oil Filter
- 22mm Front Sway Bars
- 22mm Rear Sway Bars
- Type II Lower Arm Brace
- Lower Rear Power Braces
- Lower Center Power Brace
- Brake Cylinder Stopper
- Rear Lower Subframe Bar
- 1.5 Type RS LSD
- Rear Differential cover R180 (Silver)
- Stainless Steel Clutch Cable
- Rear Trailing Arms
- Rear Laternal Links (Front and Rear)
DeatschWerks:
- DW300 Fuel Pump
- Fuel Filter
Driveshaft Shop:
- Front CV Axle Bar
- Rear CV Axle Bar
Duralift:
- Platnum Battery 35-AGM (Size 35)
Exedy:
- Release Bearing
- Lightweight Flywheel
- Stg 1 Organic Cluch Kit
GrimmSpeed:
- Top Mount Intercooler and splitter
- Y-pipe
- Gaskets (Intercooler Y-Pipe, Turbo-Downpipe, Downpipe-Catback, and Throttle Body)
HKS:
- SSQV Blow-Off Valve
IAG:
Turbo Rotated Power Steering Line
Kartboy:
- Transmission Mount Bushings
- Front and Rear Endlinks
Killer B:
- Aluminum Oil Pan Bundle (Oil Pan, Windage Tray, Pickup Pipe)
Mishimoto:
- X-Line Performance Aluminum Radiator
- Radiator Hoses (Black)
- Oil Cooler Kit (Stealth Black)
- Aluminum Coolant Expansion Tank
- 154 Degree Thermostat
NGK:
- Iridium One Step Colder Spark Plugs
PST:
- Carbon Fiber Driveshaft
Samco Sport:
- Power Steering hose
Stoptech (will have all my braking system):
- Stainless steel brake lines
- ST-40 big brake kit (For front) (slotted; yellow or blue calipers; whichever color's avilable when I'm ready)
- ST-20 big brake kit (For rear) (slotted; yellow or blue calipers; whichever color's avilable when I'm ready)
Subaru OEM:
- Water Pump
Super Pro:
- Front Lower Control Arms
Tein:
- Flex Z Coilovers
Tomei:
- Expreme Ti Catback
- Turbo Inlet
- Expreme UEL Headers
Torque Solution:
- Engine Mounts
- Transmission Mounts
- Rear Diffrential Brace
- Throttle Body Spacer
Turbosmart:
- Silicone Coupler
- Comp-Gate40 EWG (blue; will not tune to flutter)
Whiteline:
- Steering Rack Bushings
- Front Roll Center Adjustment Kit
- Subframe Locking Bolts
- Rear Trailing Arm Front / Lower Rear Bushings
- Front Pitch Stop Mount
- Rear Sway Bar Mounts
Zero/Sports:
- V-Earthing Grounding Kit
- V-Effector Voltage Stabilizer
- V-Two-Point Muffler Ground
Performance - FINAL MODS (because they require protuning; will make trip to a tuner once all are acquired):
Aeromotive:
- Fuel Regulator (will get with side feed system bundle)
Cobb:
- Boost Solenoid (Will get with WRX Stage 2 Bundle)
- 4 BAR MAP Sensor
DeatschWerks:
- 850cc Injectors
Okada Projects:
- Plasma Direct Coil Packs
Snow Performance:
- Stage 2 Boost Cooler Water-Methanol
Tomei:
- ARMS MX8265 Turbo (not a protuning part, but if I got this earlier, the OEM fuel injectors will have a hard time running it.)
TIRES & RIMS:
Falken:
- Zeix ZE960 All Seasons
Hankook:
- Ventus RS4 (for track use only)
Rays - (gram LIGHTS):
- 57FXZ (18in, Super Dark Gunmetal Black)
BODY:
Chargespeed:
- Half Composite Wing 3D Carbon (Top Half)
Ings +1:
- Rear bumper Mud Gaurds
Seibon Carbon:
- Rear Diffuser (if there's a way to tuck it under the Ings mud gaurds)
Spec-D:
- Projector Headlights (replacing halogen bulbs w/ LEDs)
Subaru OEM:
- JDM Tailights (replacing halogen bulbs w/ LEDs)
Voltex:
An LED light bar for the spoiler tailgiht
ENGINE BAY COSMETICS:
COBB:
- Delrin Oil Cab
Greddy:
- Carbon Fiber Hood Struts
Mishimoto:
- Battery Tie Down (Black)
- 1.3 Bar Radiator Cap (with temperature gauge)
PERRIN:
- Belt Cover (Black)
INTERIOR:
Cobb
- Short Throw Shifter
Kenwood (all of my audio system):
- eXcelon DDX396 Dashboard reciever
- KFC-1396PS Front Speakers
- KFC-16666S Rear Speakers
Carbon fiber-like steering wheel cover
https://www.amazon.com/Elantrip-Ste...c22c1c87ac3693db233ef22551b99b&language=en_US)
SMY:
-ClusterMaker gauge pod
Subaru OEM:
- STI Limited seats from stinkeye generation (because why go through the trouble of importing Recaro Sporsters w/ airbags when there's that)
SAFETY:
License Plate backup cam (
https://www.amazon.com/License-Wireless-LASTBUS-Universal-Waterproof/dp/B07XBC8B56)
LED bars for dashboard footwells (I'll know where the clutch and brake are at night)
