1 - 20 of 163 Posts
Hey guys... my name is Kevin and i currently own a 2010 Subaru STI in white.
This is my 3rd car and my previous cars were 2006 Mazda 3, 2008 Civic SI and now the STI. The Mazda 3 was my first car and was unfortunately automatic but it didn't stop me from modding the car. Then i saved up some money and sold the 3 and got the SI then started modding that as well but soon after i needed a power upgrade and turbo is always the way to go so i went with the STI.
STI mod list (currently on the car)
All work done by Advance Power House from Brian Wong and Kevin So
Engine/Tranny:
ATP GTX3076 R externally gated
Tial 44mm wastegate
APH custom dump tube (DEI titanium heat wrapped)
Cobb Tunning Access Port
Protuned (thanks to APH)(400whp)
PST carbon fiber drive shaft.
HKS Super Suction Intake
HKS full catless turbo back (DEI titanium heatwrapped )
HKS oil cap
HKS rad cap
HKS grounding kit
HKS SSQV4 Bov
Perrin FMIC
Denso IKH27 plugs
Cusco oil catch can
Koyo aluminum racing Radiator
Earls custom fitted oil filter relocation kit
Cusco Oil filter
Cosworth thermostat
Perrin 3" turbo inlet
Samco white upper and lower rad hose
Vibrant vacuum lines
Tomei EL headers
Setrab custom fitted oil cooler
Russell fittings
Russell stainless steel Lines
DW fuel pump/ kit
Grimspeed boost solenoid
Beatrush shifter linkage bushing
Beatrush forged pitch mount
Injector Dynamics 725cc injectors
Group N L/R engine mounts
Group N transmission mount
Perrin rear diff bushings
Exedy Twin plate carbon clutch
DEI gold heat insulation tape
Motul 300v
Motul Gear 300
Suspension/Brakes:
HKS Hipermax 3 sport coilovers
Cusco rear lower control arms
Whiteline toe link
Whiteline front roll center ball joints
Whiteline lateral link
Progress rear sway bar
Progress rear endlinks
Whiteline front 22mm sway bar
Kartboy front enlinks
Perrin front strut bar
Eibach camber bolts
Goodridge SS brakelines
Motul RBF600
DBA 5000XS drilled/slotted Fronts
DBA 4000 slotted Rears
Ferodo 2500 front pads
Ferodo 2500 rear pads
Wheels/Tires
Advan RG-D matte black
18x9 +15 front
18x9 +25 rear
Yokohama AD08 245/40/18
Interior/Exterior:
Varis front bumper
Varis X Original Runduce lip
Original Runduce carbon lip guard
Varis CF double canards
Varis Side skirts
Varis CF side skirt add-ons
Varis CF Diffuser
Varis CF Diffuser extensions
Varis CF exhaust heat shield
CF Vented hood.
R205 fender badge
WRX spoiler wrap in cf vinyl
Voltex CF GT wing for hatch back
Defi BF oil pressure
Defi BF oil Temp
Defi BF boost
Defi VSD heads up display
Prova rear view mirror blue lens
20% tints
PIAA high beam bulbs
DRL disabled
White LED dome lights
White LED map lights
White LED license plate lights
White Hella horn
Weathertech rain visor
Titanium, purple dress up bolts
Beatrush pulley aluminum plate
Beatrush purple shift knob
Beatrush aluminum cooling plate
HKS Kansai front tow hook
Prova SI drive knob
Keys! racing leather steering wheel
Prodrive quick release (made by works bell)
Works Bell short hub
Buddy Club superlow rails
Recaro Profi seat x 2
Recaro Profi back covers
Compustar 2-way alarm
Audio
Pioneer X930-BT
Morel 4x component speakers with cross overs
Custom mounted tweeters for rear doors
Custom amp box
Pioneer 4 channel amp
Pioneer 2 channel amp
Alpine RCA wires
MTX 10 inch sub
Got a new lip.
Re: Subierooo's GRB.....Takata Green>>Defi>>HKS>>Alpine>>
Updated pics (April 30th 2010)
Not the best quality pics since i recently sold my DSLR. Heres a few that i took after cleaning the car.
Those wheels are going to look super good. What color lugs are you planning on doing with them? Just simple blacks?
Discussion Starter #6
The HKS exhaust is freakin awesome. Sounds amazing and no drone at all.
The CEs are 18x9 +35. These were the last set of brand new CEs in takata green that I could find. I was thinking to put it on first then see if I want to put spacers on.
I will be putting project kics R40 lug nuts and I don't know how to describe the color. Its not quite black and its kinda bronzish
I love the wheels, i am thinking about painting the wheels on my AW this color do you have any better lit up extieror pictures?
Creeper v.02
Where are you going to mount those gauges? I don't know if it is just the picture but they look HUGE! lol. Rims are sick!!
Discussion Starter #9
Re: Subierooo's GRB.....Takata Green>>Defi>>HKS>>Alpine>> (April 30th 2010)
updated with a few pics on post #2
How are the Hipermax? Too stiff for a daily? If you could share your experience as I'm in the market for a suspension setup.
Thanks.
Discussion Starter #11
The hipermax is a little too rough for everyday driving. I have the damper set to 20 turns (max is 30) and its already killing me. I'm waiting for my camber parts to come in so i can do some adjustment. Right now i'm rubbing a little bit in the back even after rolling my fenders so i have to set it to a little stiff
Do you think it'll be different on my car as it's an 06 STI, I mean, for the drop?
Discussion Starter #13
Well the drop is really personal preference. I'm apparently in the lowest setting in the back and the front i can go a little tiny bit lower. I'm planning to raise the car back up another half an inch since its a little too low for me. If you want a little comfort do'nt get the sport version, and just get the hipermax 3
Re: Subierooo's STI.....Takata Green>>Defi>>HKS>>Alpine>> (April 30th 2010)
Your car is a 08 and the spring rate on them should be 12kg/10kg. For the 06, spring rates are 10kg/7kg, do you think it would make a little difference on the stiffeness ?
Discussion Starter #16
It will slightly make a diff but the 10k will still kinda kill ya. And i believe the 10k for you is inthe front and you're sitting in the front so you will feel every crack you drive on. Or just set your dampers softer.
already, thanks for sharing the experience!
I think I saw your car at First Markham Place on Friday at lunch. :tup:
Discussion Starter #19
Yea i was there with my gf in the food court.
Discussion Starter #20
Got a chance to do a photoshoot with one of my friends and heres how the pics came out.
1 - 20 of 163 Posts
