1 - 20 of 82 Posts
Banned
Engine Oil Change Kits:
Your choice of 8100 X-Clean Synthetic Oil ( 5W30 or 5W40 )
The Motul 8100 Series is 100% synthetic engine oil that has been formulated, developed and tested according to the most recent technical requirements of petrol and diesel engines. Motul 8100 has synthetic base stocks and specific friction modifier molecules that provide an outstanding oil film resistance, reducing friction in the engine, maintaining the oil pressure, and generally decreasing the operating temperature. 8100 provides outstanding lubricating properties against wear while offering high temperature resistance and controlled oil consumption.
For this package with your choice of the oil below, including the drain plug, and OEM filter the price would be $85 shipping would be calculated upon checkout.
5w30 X-Clean, 5L Jug part #102020
5w40 X-Clean, 5L Jug part #102051
5w40 X-Cess, 5L Jug part #102780 (X-cess oil is offers a great blend of friction efficiency, sheer protection, and low pollutants for your performance vehicle)
Or
300V Synthetic Racing Motor Oil ( 5W30 or 5W40 )
Motul 300V motorsports lubricants are specifically formulated for racing applications. They are based around Motul's unique Ester Core technology which combines the best performing synthetic base oils including esters with dedicated chemical additives. Double Ester Technology, made by carefully balancing the ratio of complex ester and the newly developed macromolecular high polymer ester, delivers high output performance and superior reliability. The result is unrivaled power increase, outstanding lubrication and optimal protection, the best conditions for ultimate victory! These lubricants have been developed for leading Factory Racing Teams Worldwide (including Mugen, Nismo, Porsche), but are made available to the general public! Under racing conditions, Motul runs exceptionally well in highly modified engines running oil temperature up to 365 degrees. For street use, you can expect unparallelled life and wear protection.
5w30 Power Racing, 2L Jug part #102020 (qty 3 required)
5w40 Power, 2L Jug part #102051 (qty 3 required)
OEM Subaru Oil Filter, PLUS replacement Drain Plug Crush Washer
Oil Filter Part # 15208AA12A
Drain Plug Crush Washer Part # 11126AA000
Transmission + Rear Differential Oil Change Kits:
Transmision GEAR 300 75W90 - Synthetic Ester
Motul's GEAR 300 line is designed for racing gear boxes and are what you need if you are serious about going fast. This synthetic gear oil was designed for extreme pressure and is more resistant at higher temperatures. Motul uses a friction modifier to avoid a noisy or dragging limited slip. Although this oil was designed to endure high temperature it is also very smooth shifting and fluid when the gear box is cold.
For this transmission package it would come out to a total of $85, shipping would be calculated upon checkout.
Gear 300 75W90 Synthetic Ester, 1L Jug part # 100118 (qty 5 required)
OEM Subaru Manual Transmission Drain Plug Washers
5 & 6-Speed Models, part # 803926090
Secondary Drain Plug Washer (6-Speed Models), part # 803916080
To Spice things up a bit with your purchase of the engine oil, filter, and oring we will throw in for FREE your choice of the Greddy magnetic drain plug
Part Number: 13901303
or Mishimoto magnetic drain plug
Part Number: MMODP-2015B
Also with any transmission kit purchase we will throw In a FREE GrimmSpeed T70 Gear Box Torx Bit
Part Number:055001
Banned
Where is the oil package on your site?
We don't have the package on the site. We will be adding it tomorrow for easier checkout on the site. If you would like to place an order just PM us!
-Chris
1 - 20 of 82 Posts
