1 - 3 of 3 Posts
Hello guys, doing a little bit of house cleaning.
I have a BNIB Steel Moroso Oil pan and Oil Pickup Tube for sale.
$350 shipped, PayPal preferred.
PM or Text with questions, Seven-O-one 330-1297
Moroso Oil Pans are wet sump pans intended for street-performance machines that occasionally see some track time. They are modified with a Deep Sump for increased capacity to improve oil control under hard acceleration and to help the engine run cooler. Moroso Oil Pans are designed for simple bolt-on installation.
Deep Sump pans offer improved oil control over stock pans because of their increased capacity. They are specially baffled. The one-way baffle keeps oil contained in the pickup area to prevent oil starvation under hard acceleration.
Features:
Manufactured from steel with a 3/8in thick laser cut oil pan rail. This provides a rigid flange for leak-free sealing
Windage Tray for increased horsepower saving and oil control
N.P.T. fitting that can be used for crank case ventilation or for head drainback
Oil Pump Pick up and o-ring included
High Grade Mounting hardware included
Wet Sump, 5.5 Quart Capacity Moroso oil pans come with a magnetic oil drain bolt. The size is 1/2x20 so if you order an aftermarket bolt make sure to order one with the correct thread size and pitch. This is not the same as the OEM Subaru size
1 - 3 of 3 Posts
