Year:2008
Make:Subaru
Model:WRX
Mileage:78500 M
Transmission:Manual
Engine:2.5L Flat 4
Trim:WRX STI
This is my 2008 Subaru WRX STI which I purchased new in December of 2008. It has always been mine. Although it has gone through many modifications, all were done with highest quality parts in mind. Having said that, the list of parts and upgrades is below. Before going on though, it has been tracked in the past, and autocrossed. All maintenance has been done to high standards. It is a fast Subbie. The car has been garage kept and the finish, while a bit marked, is in excellent condition. I guess that's because of desert living.
Parts and upgrades.
Outfront Motorsports closed deck block, with WPC treatment on rotating parts. 3k on new block.
Fuel injector Clinic 1650cc injectors. Radium surge tank with Walbro 400 for extra power. Run on E85. Cobb Flex Fuel sensor.
All fuel lines AN fitted.
Full Race Twin Scroll up-pipe, equal length headers, downpipe, with Borg-Warner 8375 EFR Turbo Twin-Scroll
Front Mount Process West Intercooler with custom piping for bigger turbo.
Kw V3 Coilovers.
Mooresport top hats for added negative Camber
Cusco Rear Lateral control Arms. White Line Ball joint front end links.
Whiteline rear sway bar.
GT spec rear trailing arms.
GT spec under body bracing.
AP Racing Pro 5000 front brakes and Rotors. These are the best brakes ever. Will stop a freight train.
Cobb Tuning Access port V3.
Defi Gauges for Oil Pressure, Boost and Oil Temp.
M7 Oil Cooler mounted with Cowl for air flow.
Closed cooling system for heat management with Koyorad Racing Cooler.
Exedy Twin Disk Clutch model Part # FM022HD
Interior has a Autopower Half Roll Cage. Bolt in.
I no longer have racing seats since I'm not racing anymore. This is a rather peppy daily driver.
Tomei Expreme TI Catback Exhaust. Yes, it sounds like a race car without the baffle.
Custom diffuser to clear the Tomei. It can be easily removed.
High flow cat from Full Race. Can be removed for cat free driving.
Killer B Motorsports Cast Performance Oil Pan w/ High Flow Pickup & Baffle
High flow Oil Pump.
Etc.
Wheels are Enkei PF01 in 18x9.5. Brand new Falken 615+ tires in 265/35/18. Less than 100 miles on the tires. Any questions about details, please DM me.
I'm sure there's more, I'll update as time permits.
Andrew
