Hey guys! Just looking for some input on some mods I’ve been thinking of running, talked to some reputable tuners around my area they’ve recommended some parts, I’ve also done research, just looking for some input anything you would change or swap out for another? I’m planning on running around 360WHP (In the end) upper end of stock block until it inevitably blows on me. It’s a 2019 STI and I’m currently running an OTS tune with the Cobb DP and catback also from Cobb.
Now the good part, stage 2 parts I want:
FPR: Aeromotive
Intake: Cobb OR ETS (can’t decide)
EBCS: custom from neetronics
Injectors: Bosch 1000 cc
Spark plugs NGK one step cooler
Pickup and baffle: Killer B
Fuel pump: AEM
Radiator: CSF
Crank Pulley: fluidampr
Now for the controversial part, I want an aftermarket BPV, fully recirculating, it may be a waste of money, but personally it’s worth it for more noise without compromising reliability. I was thinking of going with the Grimmspeed BPV, Cobb, or forge diverter valve. I’ve listened to GrimmSpeed BPV on YouTube, I’m a little nervous because it makes a clear flutter sound, so I was assuming it was compressor surge, but GrimmSpeed is very adamant its not and its how they designed it, anyone have any experience? Because the GrimmSpeed one is the one I was leaning towards.
Stage 3 parts I want:
Verticooler (I think I’m running this over front mount, from what I’ve read no heat soak + little to no turbo lag?)
Turbo: Cbob 20g or FP blue
Turbo inlet: Perrin or GrimmSpeed
Up pipe: Tomei
ELH: killer B
EWG: Tial
4 bar sensor: OMNI
oil filler neck
water/meth injection kit
TGV deletes
Any suggestions on anything would be super great, especially with the BPV. Forgot to mention I’ll be running pro tunes with both these setups obviously.
FPR: Aeromotive
Fuel pump: AEM
Radiator: CSF
Up pipe: Tomei
ELH: killer B
EWG: Tial
4 bar sensor: OMNI
oil filler neck
TGV deletes
