401 - 420 of 2040 Posts
Discussion Starter #402
Re: MK'S Limited *Updated 1/16 Upcomming plans*
:lol: that's awesome
that is pretty sweet!
Black RE30's will look much better than gold on your car. As for the hoses, what hoses did you buy (i.e. radiator, ic, etc)?
thanks guys, and yeah i agree the black RE's will definately look great with the gloss black brakes......i didn't buy the hoses yet, but im working on getting the order into samco sport.....
Indiatr0n in yo IWDPL
Nan,
on a stock suspension you can run the 9" and 255s, you'll rub under hard driving but as a temp solution it's ok with enough rear camber.
Only reason I suggested it was b/c I knew MK was getting coilovers around the same time the wheels/tires are going to show up.
nan knows first hand that when using lowering springs your "wide tire" options go out the window.
Yes I do :(
But FP struts give more inboard clearance... and I still rubbed with -1.8 on one side in the rear... So is the saving grace for MK the adjustable ride height + the stiffer CO springs? I guess that would stop the rub, to some degree.
Discussion Starter #404
im interested as well clapper, i believe you told me that with tic's specified ride height, and the stiffness of the coil it keeps it off the fenders
I could probably clear 255 RT-615s with camber bolts in the back and around -2.0. I was rubbing under load with -1.8. So the TiC springs would need to be a good bit stiffer than my JDM Pinks, and of course, the ride height would need to be sufficiently taller in the back (Pinks do dump a bit in the rear).
Discussion Starter #406
clap told me 1.5 in the back and i should be fine, also i think the 255/35R18 re01r's are a little different demension wise compared to the rt615's
I Solve Problems
it's the ride height and the stiffness of the springs.
the pinks are lower in the rear then the recommended ride height from TiC.
Nice car man. I found it on Google searching for pictures of a Pioneer AVIC Z1 in a Subaru.
Discussion Starter #410
Alright not going to spoil the fun, but im saying that there will be a large palette of parts arriving at my doorstep in the next few days, via Clint at turn-in concepts
Shouldn't you be in school instead of working to support your mod habit?
Discussion Starter #415
i dont understand the abreviation, nandaner!
Discussion Starter #417
thanks matt.....nan your just a jealous little woman, aren't ya?
Discussion Starter #419
ohhh okay.....im just slightly jealous of those tails, too bad im getting them
