241 - 260 of 303 Posts
Discussion Starter #242
Re: Matt_H's 2008 DGM STI
glad the sandblaster is being put to use ;) .......how you like the broken finger on the glove ...hahahaha
Hah I missed this earlier. It was dangerous, but had to be done. :)
Just saw some pictures of you on 19's... explain yourself.
Heh, forgot to update this thread.
Got them last week. 19x10 +25
Discussion Starter #244
Narrow/stretched tire 245/35/19
I have the same camber and fender work (roll and pull) that I've had on the last two sets of wheels, the NT03 18x9.5 +27/+40 with 255/35 and Varrstoen 18x9.5 +22 with 245/40.
Discussion Starter #247 (Edited)
Still waiting on pistons, will be sending my heads to Headgames, having 3MI building my block, Andrewtech installing it, and TurboXS tuning it.
Starting to get a list of things together.
Parts needed:
Oil pump assembly
Kelford cams 264
Springs
Retainers
ARP headstuds
Walbro 400
1600cc injectors
ARP case bolts
Engine gaskit kit
AP
KS Tech spacers
Fuel rails
Clutch
Parts to install:
Aremotive FPR
KS Tech pump block off plates
Costworth intake manifold (reverse)
GT Spec exhaust manifold
Group N trans mount
TiC Crossmember bushings
Killer B pick up
GrimmSpeed P&P TGV deletes
GrimmSpeed P&P trottle boy
GrimmSpeed boost controller
Kartboy rear endlinks
Discussion Starter #248 (Edited)
What I did over the weekend.
I think it took around 10 hours total Had to stop on day one since I needed some tools. All work was done by myself, which made things a little more time consuming.
Discussion Starter #249
Made a little bit of progress today, more importantly cleaned the garage so the wife could park in it. Pulled the harness and intake manifold as a complete unit (which is for sale :)).
EJs sucks! Sorry to hear about your motor man, been there - done that. 3MI will do a great job though! Are you going with one of their long-rod builds?
Discussion Starter #253
I am. Micah has my heads now and they will be getting a small treatment at Headgames before being bolted up to a 2.35. :)
Discussion Starter #255
I'm done with the car as far as installing anything. Once the motor goes in, all the parts I have stock piled will be going in at the same time, and Andrewtech will be doing the install. Then it's time to drive it and leave it alone. :)
Discussion Starter #258
I'm just now getting the motor back in, so it's going to the shop. Picking up the new motor tomorrow. :lol:
Discussion Starter #260
Picked up the motor the day after my last post. Dropped it off at the shop on Monday, and he's how it's looking as of earlier today.
Tentatively have a break in tune set for this Friday, pending if the motor is in and running.
