1 - 20 of 20 Posts
MSRP: $175+
Normal King of Imports Discounted Pricing is $157.99.
These need good homes, so take an additional $25 off at checkout when you enter the discount code: March
Click Here To ORDER
This offer is only good until we sell out of remaining inventory or until we choose to end this offer. Get yours today! We ship Monday through Friday and usually ship the same day if ordered before 12 PST. Comes with everything necessary for installation in your Subaru.
Here are Specifications:
Voltage: 12
AH: 15
PCA: 700 Pulse Cranking Amps
Length: 5.8”
Width: 3.3”
Height: 5.9:
Weight: 11.5 lb or 5.2kg
Use: Road Racing, Drag Racing, Rally Racing, Auto-Cross and Daily Use.
It is no secret that the lightest car retains the advantage in virtually any motorsports competition because the lightest car accelerates quicker, apexes faster, and stops shorter than its competition. That is why automotive enthusiasts continue to run the Braille B14115 No-Weight Battery in their vehicles.
Tipping the scales at a mere 11.5 lbs, this battery sheds 25 pounds or more off the front end of most vehicles. This results in a lower center of gravity and improved handling, especially when installed in conjunction with other proprietary lightweight parts engineered by Braille.
Not only is the Braille No-Weight Battery the only lightweight battery designed specifically for automotive use, but its also backed by Braille’s 1 year limited warranty. With all that, it’s no surprise that Braille batteries appear under the hoods of motorsports' top contenders.
Features
Factory Sealed Valve Regulated Design
Eliminates damage from Acid Spills - Environmentally Safe
High Density Oxide
This enables Braille to produce a "High-Cycling" lightweight battery
Heat Sealed Top Battery Cover
Eliminates Electrolyte leakage
Absorbed Demineralized Electrolyte
Improves service life and off-season storage
Heavy Duty Automotive Posts
Resist Damage from Vibration of Heavy Use - Easy installation
Calcium Full Frame Power Path Grids
Provide Highest Cranking Amp to Weight Ratio; Lowest Self-Discharge
Rate
RE: Re: RE: Re: RE: static electricty
After installing my audio equipment in my car Im really looking into shedding a little weight, but will this battery handle a serious audio system?
Discussion Starter #9
I have some customers running 800 watt stereo systems with a single Braille Battery, but we dont recommend it. They know they should not run the stereo with the car off. How much power are you running?
about 400 RMS 100x4 wattage to the doors and 800 RMS to the sub.
Not that its turned up that loud all the time, but those are the specs.
wow nice deal
1 - 20 of 20 Posts
