1 - 3 of 3 Posts
Ever since I installed my DR725 intercooler I have had some pretty bad bogging/histation when I go WOT. It lasts for around 3-5sec then the car starts pulling, happens again when I go WOT in the next gear.
Mods,
APS CAI
Invidia DP Catless
HKS TI Catback
DR725
Walbro 255
Zero sport thermo
Ecutek tuned by MZM
This is a 2nd, 3rd & 4th gear pull.
Time Fuel Injector #1 Duty (%) Knock Correction (°BTDC) Ignition Timing (°BTDC) Mass Air Flow (g/s) Coolant Temperature (°C) Throttle Opening Angle (%) Intake Air Temperature (°C) Vehicle Speed (KPH) Air/Fuel Sensor #1 (AFR) Engine Speed (RPM) Manifold Relative Pressure (PSI)
219 4.25 -1 38 15.96 86 10.98 68 24 13.78 1994 -7.835
375 12.85 2 38 50.82 86 77.65 68 24 13.09 2151 -0.29
547 12.96 5 25 41.99 86 100 68 25 14.01 2095 0.29
719 14.94 5 25 49 86 100 68 25 13.78 2260 0.725
891 16.2 4 26 52.34 86 100 68 25 13.44 2450 1.161
1063 18.67 5 24 58.51 86 100 68 26 13.32 2574 1.741
1235 19.03 5 23 64.43 86 100 68 26 13.09 2623 2.322
1391 21.79 5 22 69.05 86 100 68 29 12.75 2761 3.047
1563 26.43 6 21 85.92 86 100 68 29 11.71 2950 3.773
1735 32.29 7 18 96.31 86 100 67 29 11.14 3089 4.933
1907 38.9 5 14 113.72 86 100 67 33 11.14 3199 6.529
2078 46.84 5 13 131.42 86 100 67 33 11.14 3327 8.706
2250 56.94 5 11 159.56 86 100 67 33 11.14 3466 11.318
2407 67.46 4 8 181.69 86 100 67 38 11.14 3553 14.51
2578 74.87 4 7 201.74 86 100 67 38 11.14 3694 17.267
2750 77.3 4 7 202.99 86 100 67 38 11.14 3855 18.427
2922 81.51 4 8 209.76 86 100 67 43 11.14 4022 18.427
3094 80.37 4 10 217.01 86 100 66 43 11.14 4233 18.427
3266 84.97 4 11 231.35 86 100 66 48 11.14 4426 18.427
3438 87.22 4 12 230.42 86 100 66 48 11.14 4699 18.427
3610 89.67 4 13 240.11 86 100 66 48 11.14 4888 18.427
3766 93.05 4 13 249 86 100 66 54 11.14 5072 18.137
3938 95.69 4 14 258.91 86 100 65 54 11.14 5277 17.412
4094 96.32 4 14 263.39 86 100 65 54 11.14 5440 16.976
4266 96.58 5 16 261.97 86 100 65 61 11.14 5659 16.541
4453 97.29 5 16 264.66 86 100 64 61 11.14 5847 16.106
4610 98.56 5 17 265.45 86 100 64 61 11.14 6000 15.671
4782 96.14 5 19 262.65 86 100 64 68 11.14 6174 15.09
4953 98.59 5 20 262.13 86 100 64 68 11.14 6331 14.51
5125 101.11 5 21 270.94 86 100 63 68 11.14 6493 14.365
5297 99.92 5 22 266.96 86 100 63 74 11.14 6597 14.075
5469 98.78 5 23 262.78 87 69.8 62 74 11.14 6809 12.188
5625 4.11 0 18 39.54 87 10.98 62 80 11.37 6416 -6.82
5797 3.83 0 18 13.55 87 10.59 62 80 12.4 5982 -10.157
5969 3.6 0 24 5.09 87 10.98 61 80 13.78 5620 -10.882
6141 18.71 0 38 82.6 87 58.43 61 83 16.19 5158 1.016
6313 58.3 4 6 173.21 87 100 61 83 18.03 5157 3.918
6485 87.61 5 5 236.34 87 100 61 83 14.7 5008 9.286
6657 96.33 5 16 238.05 87 100 60 86 13.09 5131 13.059
6828 97 2 12 250.89 87 100 60 86 11.71 5052 15.671
7000 98.21 2 12 257.19 87 100 60 86 11.14 5115 16.831
7157 97.96 2 13 262.14 87 100 60 86 11.14 5278 17.122
7328 97.25 2 13 260.28 87 100 60 86 11.14 5301 17.122
7500 96.4 2 13 258.87 87 100 60 86 11.14 5380 16.976
7672 96.27 3 14 258.78 87 100 59 89 11.14 5503 16.831
7844 97.41 3 15 260.56 87 100 59 89 11.14 5637 16.686
8016 97.77 3 15 262.8 87 100 59 92 11.14 5729 16.541
8188 96.89 3 17 260.44 87 100 59 92 11.14 5823 16.106
8360 99.97 5 18 265.44 87 100 58 92 11.14 5932 15.816
8532 98.68 5 19 264.44 87 100 58 96 11.14 6007 15.671
8703 97.43 5 20 261.17 87 100 58 96 11.14 6089 15.235
8875 99.47 5 21 262.95 88 100 58 96 11.14 6217 14.945
9032 97.39 5 22 261.09 88 100 58 100 11.14 6341 14.655
9203 97.08 5 23 260.55 88 100 57 100 11.14 6410 14.51
9375 100.39 5 24 269.39 88 100 57 100 11.14 6536 14.22
9547 100.01 5 24 264.11 88 100 57 105 11.14 6603 14.22
9719 99.34 5 25 260.41 88 100 57 105 11.14 6652 14.075
9891 100.6 5 25 266.35 88 100 57 110 11.14 6737 14.075
10047 97.98 5 26 262.61 88 62.35 56 110 11.14 6855 11.898
10219 4.09 0 20 49.25 88 10.98 56 110 11.25 6391 -6.675
10407 3.81 0 20 17.89 88 10.2 56 113 12.17 5954 -9.867
10578 3.56 0 24 5.91 88 9.8 56 113 12.63 5559 -11.173
10750 5.52 0 31 12.4 88 23.92 56 113 14.13 5174 -8.271
10922 47.42 3 20 152.96 88 100 56 115 17.11 5422 2.031
11078 83.77 5 7 220.5 88 100 56 115 14.59 5167 7.255
11250 98.41 4 18 245.4 88 100 56 115 12.98 5183 12.769
11422 95.65 4 18 251.15 88 100 56 116 11.71 5275 15.38
11594 97.26 4 17 256.58 88 100 56 116 11.14 5241 16.541
11766 97.32 4 17 260.19 89 100 56 117 11.14 5367 16.831
11938 96.73 4 18 263.36 89 100 56 117 11.14 5398 16.976
12110 96.61 4 18 260.62 89 100 56 117 11.14 5456 17.122
12282 96.06 5 19 262.85 89 100 56 119 11.14 5492 16.976
12453 94.58 5 19 263.36 89 100 55 119 11.14 5612 16.831
12625 98.21 5 19 265.07 89 100 55 119 11.14 5683 16.686
12782 96.1 5 20 267.45 89 100 55 122 11.14 5702 16.541
12938 97.24 5 20 260.01 89 100 55 122 11.14 5770 16.251
13110 97.13 5 20 265 89 100 55 122 11.14 5837 16.106
13282 96.22 5 21 261.76 89 100 55 126 11.14 5935 16.106
13453 95.35 5 21 260.35 89 100 55 126 11.14 5959 15.816
13625 96.38 5 21 257.61 89 100 55 126 11.14 6024 15.671
13797 96.23 5 22 257.58 89 100 54 130 11.14 6096 15.525
13969 99.04 5 22 269.12 89 100 54 130 11.14 6190 15.235
14125 98.75 5 23 265.67 89 100 54 134 11.14 6255 15.09
14297 98.69 5 24 264.24 89 100 54 134 11.14 6251 14.945
14469 98.64 5 24 266.56 89 100 54 134 11.14 6334 14.655
14641 98 5 25 268.46 89 100 54 138 11.14 6380 14.655
14813 95.75 5 25 265.59 89 100 53 138 11.14 6412 14.51
14985 96.53 5 26 263.6 89 100 53 138 11.14 6464 14.51
15141 96.36 5 26 260.86 90 100 53 141 11.14 6546 14.365
15328 96.69 5 27 262.19 90 100 53 141 11.14 6569 14.51
15500 98.77 5 27 275.65 90 84.71 53 141 11.14 6614 13.349
15657 4.05 0 23 40.14 90 11.76 53 144 11.14 6334 -4.788
15828 3.83 0 23 24.26 90 10.59 53 144 11.25 5988 -9.431
16000 3.57 0 23 6.51 90 10.59 52 146 11.83 5583 -10.882
16172 3.32 0 24 7.61 90 11.76 52 146 13.09 5185 -10.737
16328 3.08 0 24 10.32 90 10.59 52 146 14.7 4805 -11.027
16500 2.81 0 24 10.6 90 10.2 53 147 18.15 4387 -11.027
16672 2.53 0 24 11.36 90 9.8 53 147 20.33 3950 -10.882
16844 2.32 0 24 11.67 90 9.41 53 147 20.33 3629 -10.737
17016 2.07 0 24 10.85 90 9.02 53 147 20.33 3236 -10.447
17188 1.85 0 24 10.74 90 8.24 53 147 20.33 2895 -10.447
17344 1.62 0 24 9.85 90 7.84 53 147 20.33 2531 -10.592
17516 1.41 0 24 8.82 90 7.45 53 147 20.33 2204 -10.447
17688 1.19 0 24 8.25 90 7.45 53 147 20.33 1862 -10.157
Timing and k/c look ok, and boost seems a bit low up top but ok. The only thing I see that would be your problem is your IDC are maxed out pretty much all over the place. This would lead me to believe that you are running too rich and likely the bogging you are feelings. A wideband o2 would be the only way to check that out but other than that I would say that the AVCS could be tuned more aggressively to spool faster and eliminate some bog. An intercooler that large is going to cause lag on the stock turbo so it may be something you need to live with or remove it, or get a larger turbo if tuning is not the problem.
1 - 3 of 3 Posts
