Did you read this thread? I'm not sure there is much more information out there on alignment with factory camber bolts. Hope that helps
this.Toe kills tires not really camber. Go zero toe, -2.5 front camber, -1.5 rear camber, max caster for the street.
Stiggysaurus;Did you read this thread? I'm not sure there is much more information out there on alignment with factory camber bolts. Hope that helps
As far as inside corner wear, if you're seeing a very steep angled maybe 1" wide wear pattern it maybe that you need bigger/stiffer swaybars to offset body roll. I found that going to larger bars really helped eliminate the inside scrubbing.this.
these are my current alignment settings also. on the stock dunlops the front inside tread was getting pretty chewed up, but i think this is a tire defect, not because of the camber. Or I'm not cornering hard enough lol:lol: Anywhere from -1.5 to -2.5 is fine for fronts (with the help of camber bolts).
just recently swapped over to 255/45/18 MSS, and so far the wear seems much more consistent, as well as the ride and grip levels.
the alignment settings above are very good though. They will make a huge difference in how the car turns in and powers out in turns. you will feel it the instant you dive into the first corner. I never realized how bad the factory specs were. Mine were way out of spec.
I have a 24mm bar in the front at the softer setting. At stiff setting I'm getting too much under steer. 22mm in back at stiff.As far as inside corner wear, if you're seeing a very steep angled maybe 1" wide wear pattern it maybe that you need bigger/stiffer swaybars to offset body roll. I found that going to larger bars really helped eliminate the inside scrubbing.
