1 - 15 of 15 Posts
Target peak is 16.5 +/- .5 psi. On the log Right at 3500 rpm I am peaking 17.8!!! intake temps were 68*. Should I switch to the LWG version? Also I noticed the Fuel pump duty was 100% after the onset of boost. Is that normal. 100% is maxing it out right?
walbro 255 $80 just to be safe
well if you just installed its possible you need to give ECU some time to learn if things dont get better than i guess you could use a different map
and you shouldnt have to replace your fuel pump with just stage 1...this stage is for stock cars and there are a lot of people that are running stage 2 with stock pumps...i would guess if your pump cant handle stage 1 than there is something wrong with your pump but that seems pretty unlikely
I'd switch to the low wastegate map. Almost 18 on stage 1 is too much. Although I can't talk too much since I'm pushing 20psi on my stg 2 protune.
Do you have a map to post? How long is it at 17.8? People need to know this in order to give you their honest opinion. If your suffering from boost spikes, than it's not as big a deal. If your experience boost creep, well thats a huge problem.
Discussion Starter · #9 ·
It's not boost creep, it spikes to 17.8, by redline it has tappered down to 14.4 wich is the norm for stage 1.
I will post the whole log.
Discussion Starter · #10 ·
ok here is a 4th gear log i did this morning. not quite as high. what is the proper proceedure for taking off for a log. what rpm should the roll on in fourth occur?
<table x:str="" style="border-collapse: collapse; width: 432pt;" border="0" cellpadding="0" cellspacing="0" width="576"><col style="width: 48pt;" span="9" width="64"> <tbody><tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 48pt;" height="17" width="64">Time</td> <td style="width: 48pt;" width="64">Engine Speed (RPM)</td> <td style="width: 48pt;" width="64">Intake Air Temperature (°F)</td> <td style="width: 48pt;" width="64">Vehicle Speed (MPH)</td> <td style="width: 48pt;" width="64">Fuel Injector #1 Duty (%)</td> <td style="width: 48pt;" width="64">Manifold Relative Pressure (PSI)</td> <td style="width: 48pt;" width="64">Primary Wastegate Duty Cycle (%)</td> <td style="width: 48pt;" width="64">Fuel Pump Duty (%)</td> <td style="width: 48pt;" width="64">Ignition Timing (°BTDC)</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">0</td> <td x:num="" align="right">2183</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">30</td> <td x:num="" align="right">13.04</td> <td x:num="-0.14499999999999999" align="right">-0.145</td> <td x:num="" align="right">25.49</td> <td x:num="" align="right">33.33</td> <td x:num="" align="right">33</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">130</td> <td x:num="" align="right">2206</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">30</td> <td x:num="" align="right">12.71</td> <td x:num="" align="right">0.29</td> <td x:num="" align="right">29.8</td> <td x:num="" align="right">33.33</td> <td x:num="" align="right">32</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">261</td> <td x:num="" align="right">2235</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">30</td> <td x:num="" align="right">13.35</td> <td x:num="0.72499999999999998" align="right">0.725</td> <td x:num="" align="right">68.24</td> <td x:num="" align="right">33.33</td> <td x:num="" align="right">30</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">391</td> <td x:num="" align="right">2252</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">30</td> <td x:num="" align="right">12.01</td> <td x:num="1.016" align="right">1.016</td> <td x:num="" align="right">75.69</td> <td x:num="" align="right">33.33</td> <td x:num="" align="right">30</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">521</td> <td x:num="" align="right">2306</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">30</td> <td x:num="" align="right">12.3</td> <td x:num="1.306" align="right">1.306</td> <td x:num="" align="right">75.69</td> <td x:num="" align="right">33.33</td> <td x:num="" align="right">29</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">651</td> <td x:num="" align="right">2344</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">30</td> <td x:num="" align="right">13.5</td> <td x:num="1.7410000000000001" align="right">1.741</td> <td x:num="" align="right">75.69</td> <td x:num="" align="right">33.33</td> <td x:num="" align="right">30</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">781</td> <td x:num="" align="right">2334</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">31</td> <td x:num="" align="right">14.94</td> <td x:num="2.0310000000000001" align="right">2.031</td> <td x:num="" align="right">75.69</td> <td x:num="" align="right">33.33</td> <td x:num="" align="right">30</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">911</td> <td x:num="" align="right">2333</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">31</td> <td x:num="" align="right">14.93</td> <td x:num="2.4670000000000001" align="right">2.467</td> <td x:num="" align="right">75.69</td> <td x:num="" align="right">33.33</td> <td x:num="" align="right">28</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">1042</td> <td x:num="" align="right">2395</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">31</td> <td x:num="" align="right">15.84</td> <td x:num="2.7570000000000001" align="right">2.757</td> <td x:num="" align="right">75.69</td> <td x:num="" align="right">33.33</td> <td x:num="" align="right">27</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">1162</td> <td x:num="" align="right">2435</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">31</td> <td x:num="" align="right">16.62</td> <td x:num="3.0470000000000002" align="right">3.047</td> <td x:num="" align="right">75.69</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">27</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">1292</td> <td x:num="" align="right">2456</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">32</td> <td x:num="" align="right">16.76</td> <td x:num="3.4820000000000002" align="right">3.482</td> <td x:num="" align="right">74.9</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">26</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">1422</td> <td x:num="" align="right">2494</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">32</td> <td x:num="" align="right">17.56</td> <td x:num="3.7730000000000001" align="right">3.773</td> <td x:num="" align="right">74.51</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">26</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">1552</td> <td x:num="" align="right">2554</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">32</td> <td x:num="" align="right">18.52</td> <td x:num="4.2080000000000002" align="right">4.208</td> <td x:num="" align="right">74.12</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">25</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">1683</td> <td x:num="" align="right">2568</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">34</td> <td x:num="" align="right">18.63</td> <td x:num="4.4980000000000002" align="right">4.498</td> <td x:num="" align="right">73.73</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">25</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">1813</td> <td x:num="" align="right">2616</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">34</td> <td x:num="" align="right">19.53</td> <td x:num="4.9329999999999998" align="right">4.933</td> <td x:num="" align="right">73.33</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">22</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">1943</td> <td x:num="" align="right">2626</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">34</td> <td x:num="" align="right">20.73</td> <td x:num="5.3689999999999998" align="right">5.369</td> <td x:num="" align="right">72.55</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">21</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">2073</td> <td x:num="" align="right">2679</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">34</td> <td x:num="" align="right">21.72</td> <td x:num="5.8040000000000003" align="right">5.804</td> <td x:num="" align="right">72.16</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">20</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">2203</td> <td x:num="" align="right">2725</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">35</td> <td x:num="" align="right">22.67</td> <td x:num="6.2389999999999999" align="right">6.239</td> <td x:num="" align="right">72.16</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">19</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">2323</td> <td x:num="" align="right">2775</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">35</td> <td x:num="" align="right">23.68</td> <td x:num="" align="right">6.82</td> <td x:num="" align="right">71.37</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">18</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">2464</td> <td x:num="" align="right">2798</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">35</td> <td x:num="" align="right">25.07</td> <td x:num="" align="right">7.4</td> <td x:num="" align="right">70.98</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">17</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">2584</td> <td x:num="" align="right">2834</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">35</td> <td x:num="" align="right">27.21</td> <td x:num="8.125" align="right">8.125</td> <td x:num="" align="right">70.59</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">16</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">2714</td> <td x:num="" align="right">2891</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">37</td> <td x:num="" align="right">30.84</td> <td x:num="8.7059999999999995" align="right">8.706</td> <td x:num="" align="right">69.8</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">18</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">2844</td> <td x:num="" align="right">2966</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">37</td> <td x:num="" align="right">33.53</td> <td x:num="9.2859999999999996" align="right">9.286</td> <td x:num="" align="right">68.63</td> <td x:num="" align="right">100</td> <td x:num="" align="right">17</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">2974</td> <td x:num="" align="right">3023</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">37</td> <td x:num="" align="right">35.47</td> <td x:num="10.012" align="right">10.012</td> <td x:num="" align="right">68.24</td> <td x:num="" align="right">100</td> <td x:num="" align="right">17</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3095</td> <td x:num="" align="right">3054</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">39</td> <td x:num="" align="right">37.79</td> <td x:num="10.882" align="right">10.882</td> <td x:num="" align="right">67.84</td> <td x:num="" align="right">100</td> <td x:num="" align="right">16</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3235</td> <td x:num="" align="right">3097</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">39</td> <td x:num="" align="right">40.3</td> <td x:num="11.753" align="right">11.753</td> <td x:num="" align="right">67.06</td> <td x:num="" align="right">100</td> <td x:num="" align="right">15</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3355</td> <td x:num="" align="right">3167</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">39</td> <td x:num="" align="right">43.23</td> <td x:num="12.624000000000001" align="right">12.624</td> <td x:num="" align="right">66.27</td> <td x:num="" align="right">100</td> <td x:num="" align="right">15</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3485</td> <td x:num="" align="right">3236</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">39</td> <td x:num="" align="right">46.26</td> <td x:num="13.638999999999999" align="right">13.639</td> <td x:num="" align="right">65.88</td> <td x:num="" align="right">100</td> <td x:num="" align="right">14</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3615</td> <td x:num="" align="right">3290</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">42</td> <td x:num="" align="right">49.82</td> <td x:num="14.654999999999999" align="right">14.655</td> <td x:num="" align="right">65.88</td> <td x:num="" align="right">100</td> <td x:num="" align="right">13</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3746</td> <td x:num="" align="right">3370</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">42</td> <td x:num="" align="right">53.21</td> <td x:num="15.525" align="right">15.525</td> <td x:num="" align="right">65.88</td> <td x:num="" align="right">100</td> <td x:num="" align="right">13</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3866</td> <td x:num="" align="right">3433</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">42</td> <td x:num="" align="right">55.66</td> <td x:num="16.106000000000002" align="right">16.106</td> <td x:num="" align="right">65.88</td> <td x:num="" align="right">100</td> <td x:num="" align="right">13</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4006</td> <td x:num="" align="right">3516</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">42</td> <td x:num="" align="right">58.5</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">65.88</td> <td x:num="" align="right">100</td> <td x:num="" align="right">13</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4126</td> <td x:num="" align="right">3562</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">44</td> <td x:num="" align="right">60.02</td> <td x:num="16.975999999999999" align="right">16.976</td> <td x:num="" align="right">64.71</td> <td x:num="" align="right">100</td> <td x:num="" align="right">13</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4256</td> <td x:num="" align="right">3650</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">44</td> <td x:num="" align="right">63.07</td> <td x:num="17.411999999999999" align="right">17.412</td> <td x:num="" align="right">63.53</td> <td x:num="" align="right">100</td> <td x:num="" align="right">13</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4386</td> <td x:num="" align="right">3687</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">44</td> <td x:num="" align="right">63.7</td> <td x:num="17.556999999999999" align="right">17.557</td> <td x:num="" align="right">62.35</td> <td x:num="" align="right">100</td> <td x:num="" align="right">14</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4517</td> <td x:num="" align="right">3737</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">47</td> <td x:num="" align="right">64.58</td> <td x:num="17.556999999999999" align="right">17.557</td> <td x:num="" align="right">61.18</td> <td x:num="" align="right">100</td> <td x:num="" align="right">14</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4637</td> <td x:num="" align="right">3821</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">47</td> <td x:num="" align="right">66.02</td> <td x:num="17.556999999999999" align="right">17.557</td> <td x:num="" align="right">60</td> <td x:num="" align="right">100</td> <td x:num="" align="right">14</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4777</td> <td x:num="" align="right">3870</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">47</td> <td x:num="" align="right">66.88</td> <td x:num="17.556999999999999" align="right">17.557</td> <td x:num="" align="right">59.22</td> <td x:num="" align="right">100</td> <td x:num="" align="right">15</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4897</td> <td x:num="" align="right">3980</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">47</td> <td x:num="" align="right">67.93</td> <td x:num="17.411999999999999" align="right">17.412</td> <td x:num="" align="right">58.04</td> <td x:num="" align="right">100</td> <td x:num="" align="right">16</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">5027</td> <td x:num="" align="right">4026</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">50</td> <td x:num="" align="right">68.71</td> <td x:num="17.411999999999999" align="right">17.412</td> <td x:num="" align="right">56.86</td> <td x:num="" align="right">100</td> <td x:num="" align="right">16</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">5158</td> <td x:num="" align="right">4106</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">50</td> <td x:num="" align="right">69.19</td> <td x:num="17.266999999999999" align="right">17.267</td> <td x:num="" align="right">56.47</td> <td x:num="" align="right">100</td> <td x:num="" align="right">16</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">5288</td> <td x:num="" align="right">4165</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">50</td> <td x:num="" align="right">71.09</td> <td x:num="17.411999999999999" align="right">17.412</td> <td x:num="" align="right">55.69</td> <td x:num="" align="right">100</td> <td x:num="" align="right">17</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">5408</td> <td x:num="" align="right">4220</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">50</td> <td x:num="" align="right">71.13</td> <td x:num="17.266999999999999" align="right">17.267</td> <td x:num="" align="right">54.9</td> <td x:num="" align="right">100</td> <td x:num="" align="right">17</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">5548</td> <td x:num="" align="right">4335</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">54</td> <td x:num="" align="right">73.98</td> <td x:num="17.122" align="right">17.122</td> <td x:num="" align="right">54.12</td> <td x:num="" align="right">100</td> <td x:num="" align="right">17</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">5668</td> <td x:num="" align="right">4377</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">54</td> <td x:num="" align="right">73.77</td> <td x:num="17.122" align="right">17.122</td> <td x:num="" align="right">53.73</td> <td x:num="" align="right">100</td> <td x:num="" align="right">17</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">5798</td> <td x:num="" align="right">4455</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">54</td> <td x:num="" align="right">76.02</td> <td x:num="16.975999999999999" align="right">16.976</td> <td x:num="" align="right">53.33</td> <td x:num="" align="right">100</td> <td x:num="" align="right">17</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">5929</td> <td x:num="" align="right">4483</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">58</td> <td x:num="" align="right">75.55</td> <td x:num="16.975999999999999" align="right">16.976</td> <td x:num="" align="right">52.94</td> <td x:num="" align="right">100</td> <td x:num="" align="right">18</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">6059</td> <td x:num="" align="right">4581</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">58</td> <td x:num="" align="right">77.21</td> <td x:num="16.831" align="right">16.831</td> <td x:num="" align="right">52.55</td> <td x:num="" align="right">100</td> <td x:num="" align="right">18</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">6179</td> <td x:num="" align="right">4649</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">58</td> <td x:num="" align="right">78.34</td> <td x:num="16.686" align="right">16.686</td> <td x:num="" align="right">52.55</td> <td x:num="" align="right">100</td> <td x:num="" align="right">19</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">6319</td> <td x:num="" align="right">4732</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">58</td> <td x:num="" align="right">78.73</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">52.94</td> <td x:num="" align="right">100</td> <td x:num="" align="right">19</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">6439</td> <td x:num="" align="right">4789</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">62</td> <td x:num="" align="right">79.68</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">52.94</td> <td x:num="" align="right">100</td> <td x:num="" align="right">19</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">6570</td> <td x:num="" align="right">4799</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">62</td> <td x:num="" align="right">79.85</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">53.33</td> <td x:num="" align="right">100</td> <td x:num="" align="right">20</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">6700</td> <td x:num="" align="right">4887</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">62</td> <td x:num="" align="right">81.31</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">54.12</td> <td x:num="" align="right">100</td> <td x:num="" align="right">20</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">6830</td> <td x:num="" align="right">4909</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">62</td> <td x:num="" align="right">80.63</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">54.51</td> <td x:num="" align="right">100</td> <td x:num="" align="right">20</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">6950</td> <td x:num="" align="right">5011</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">65</td> <td x:num="" align="right">82.32</td> <td x:num="16.251000000000001" align="right">16.251</td> <td x:num="" align="right">55.69</td> <td x:num="" align="right">100</td> <td x:num="" align="right">20</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">7090</td> <td x:num="" align="right">5085</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">65</td> <td x:num="" align="right">83.52</td> <td x:num="16.251000000000001" align="right">16.251</td> <td x:num="" align="right">55.69</td> <td x:num="" align="right">100</td> <td x:num="" align="right">20</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">7211</td> <td x:num="" align="right">5147</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">65</td> <td x:num="" align="right">83.45</td> <td x:num="16.106000000000002" align="right">16.106</td> <td x:num="" align="right">56.86</td> <td x:num="" align="right">100</td> <td x:num="" align="right">20</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">7341</td> <td x:num="" align="right">5211</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">68</td> <td x:num="" align="right">84.49</td> <td x:num="15.961" align="right">15.961</td> <td x:num="" align="right">58.04</td> <td x:num="" align="right">100</td> <td x:num="" align="right">21</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">7471</td> <td x:num="" align="right">5265</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">68</td> <td x:num="" align="right">84.24</td> <td x:num="15.816000000000001" align="right">15.816</td> <td x:num="" align="right">58.82</td> <td x:num="" align="right">100</td> <td x:num="" align="right">21</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">7601</td> <td x:num="" align="right">5336</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">68</td> <td x:num="" align="right">84.24</td> <td x:num="15.670999999999999" align="right">15.671</td> <td x:num="" align="right">60</td> <td x:num="" align="right">100</td> <td x:num="" align="right">21</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">7721</td> <td x:num="" align="right">5345</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">68</td> <td x:num="" align="right">84.38</td> <td x:num="15.525" align="right">15.525</td> <td x:num="" align="right">60.78</td> <td x:num="" align="right">100</td> <td x:num="" align="right">21</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">7861</td> <td x:num="" align="right">5392</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">71</td> <td x:num="" align="right">86.28</td> <td x:num="15.525" align="right">15.525</td> <td x:num="" align="right">61.96</td> <td x:num="" align="right">100</td> <td x:num="" align="right">21</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">7982</td> <td x:num="" align="right">5504</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">71</td> <td x:num="" align="right">86.89</td> <td x:num="" align="right">15.38</td> <td x:num="" align="right">63.14</td> <td x:num="" align="right">100</td> <td x:num="" align="right">21</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">8112</td> <td x:num="" align="right">5549</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">71</td> <td x:num="" align="right">87.59</td> <td x:num="15.234999999999999" align="right">15.235</td> <td x:num="" align="right">64.71</td> <td x:num="" align="right">100</td> <td x:num="" align="right">21</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">8242</td> <td x:num="" align="right">5572</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">71</td> <td x:num="" align="right">86.77</td> <td x:num="" align="right">15.09</td> <td x:num="" align="right">65.88</td> <td x:num="" align="right">100</td> <td x:num="" align="right">22</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">8372</td> <td x:num="" align="right">5631</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">74</td> <td x:num="" align="right">86.49</td> <td x:num="14.945" align="right">14.945</td> <td x:num="" align="right">67.45</td> <td x:num="" align="right">100</td> <td x:num="" align="right">22</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">8492</td> <td x:num="" align="right">5687</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">74</td> <td x:num="" align="right">87.34</td> <td x:num="14.945" align="right">14.945</td> <td x:num="" align="right">68.63</td> <td x:num="" align="right">100</td> <td x:num="" align="right">22</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">8633</td> <td x:num="" align="right">5730</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">74</td> <td x:num="" align="right">86.78</td> <td x:num="" align="right">14.8</td> <td x:num="" align="right">69.8</td> <td x:num="" align="right">100</td> <td x:num="" align="right">22</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">8753</td> <td x:num="" align="right">5778</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">77</td> <td x:num="" align="right">87.51</td> <td x:num="14.654999999999999" align="right">14.655</td> <td x:num="" align="right">71.37</td> <td x:num="" align="right">100</td> <td x:num="" align="right">23</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">8883</td> <td x:num="" align="right">5872</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">77</td> <td x:num="" align="right">86.44</td> <td x:num="" align="right">14.51</td> <td x:num="" align="right">72.55</td> <td x:num="" align="right">100</td> <td x:num="" align="right">23</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">9013</td> <td x:num="" align="right">5891</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">77</td> <td x:num="" align="right">87.97</td> <td x:num="14.654999999999999" align="right">14.655</td> <td x:num="" align="right">73.73</td> <td x:num="" align="right">100</td> <td x:num="" align="right">23</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">9143</td> <td x:num="" align="right">5964</td> <td x:num="" align="right">71.6</td> <td x:num="" align="right">77</td> <td x:num="" align="right">87.79</td> <td x:num="14.365" align="right">14.365</td> <td x:num="" align="right">75.29</td> <td x:num="" align="right">100</td> <td x:num="" align="right">23
</td> </tr> </tbody></table>
Discussion Starter · #11 ·
here is the 5th gear peak. the fuel duty at 100 is kind concerning. what is everyone elses pumps doin after boost onsets?
<table x:str="" style="border-collapse: collapse; width: 336pt;" border="0" cellpadding="0" cellspacing="0" width="448"><col style="width: 48pt;" span="7" width="64"> <tbody><tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 48pt;" x:num="" align="right" height="17" width="64">
3011</td> <td style="width: 48pt;" width="64">
</td> <td style="width: 48pt;" x:num="" align="right" width="64">53</td> <td style="width: 48pt;" x:num="" align="right" width="64">42.39</td> <td style="width: 48pt;" x:num="14.074999999999999" align="right" width="64">14.075</td> <td style="width: 48pt;" x:num="" align="right" width="64">68.24</td> <td style="width: 48pt;" x:num="" align="right" width="64">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3061</td> <td>
</td> <td x:num="" align="right">55</td> <td x:num="" align="right">43.75</td> <td x:num="14.654999999999999" align="right">14.655</td> <td x:num="" align="right">67.84</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3066</td> <td>
</td> <td x:num="" align="right">55</td> <td x:num="" align="right">44.47</td> <td x:num="" align="right">15.09</td> <td x:num="" align="right">67.84</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3109</td> <td>
</td> <td x:num="" align="right">55</td> <td x:num="" align="right">45.77</td> <td x:num="15.525" align="right">15.525</td> <td x:num="" align="right">67.06</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3139</td> <td>
</td> <td x:num="" align="right">57</td> <td x:num="" align="right">46.21</td> <td x:num="15.961" align="right">15.961</td> <td x:num="" align="right">66.67</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3170</td> <td>
</td> <td x:num="" align="right">57</td> <td x:num="" align="right">48.01</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">66.27</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3227</td> <td>
</td> <td x:num="" align="right">57</td> <td x:num="" align="right">49.57</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">65.88</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3260</td> <td>
</td> <td x:num="" align="right">57</td> <td x:num="" align="right">48.68</td> <td x:num="16.686" align="right">16.686</td> <td x:num="" align="right">65.1</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3299</td> <td>
</td> <td x:num="" align="right">60</td> <td x:num="" align="right">49.97</td> <td x:num="16.831" align="right">16.831</td> <td x:num="" align="right">64.71</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3323</td> <td>
</td> <td x:num="" align="right">60</td> <td x:num="" align="right">52.45</td> <td x:num="16.975999999999999" align="right">16.976</td> <td x:num="" align="right">63.92</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3345</td> <td>
</td> <td x:num="" align="right">60</td> <td x:num="" align="right">52.81</td> <td x:num="16.975999999999999" align="right">16.976</td> <td x:num="" align="right">63.14</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3397</td> <td>
</td> <td x:num="" align="right">62</td> <td x:num="" align="right">55.08</td> <td x:num="17.266999999999999" align="right">17.267</td> <td x:num="" align="right">61.96</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3408</td> <td>
</td> <td x:num="" align="right">62</td> <td x:num="" align="right">55.25</td> <td x:num="17.411999999999999" align="right">17.412</td> <td x:num="" align="right">60.78</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3463</td> <td>
</td> <td x:num="" align="right">62</td> <td x:num="" align="right">57.62</td> <td x:num="17.556999999999999" align="right">17.557</td> <td x:num="" align="right">59.22</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3483</td> <td>
</td> <td x:num="" align="right">62</td> <td x:num="" align="right">57.95</td> <td x:num="17.702000000000002" align="right">17.702</td> <td x:num="" align="right">57.25</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3539</td> <td>
</td> <td x:num="" align="right">65</td> <td x:num="" align="right">58.88</td> <td x:num="17.847000000000001" align="right">17.847</td> <td x:num="" align="right">55.69</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3564</td> <td>
</td> <td x:num="" align="right">65</td> <td x:num="" align="right">60.07</td> <td x:num="17.702000000000002" align="right">17.702</td> <td x:num="" align="right">54.12</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3569</td> <td>
</td> <td x:num="" align="right">65</td> <td x:num="" align="right">60.14</td> <td x:num="17.702000000000002" align="right">17.702</td> <td x:num="" align="right">52.94</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3624</td> <td>
</td> <td x:num="" align="right">65</td> <td x:num="" align="right">59.52</td> <td x:num="17.266999999999999" align="right">17.267</td> <td x:num="" align="right">51.76</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3647</td> <td>
</td> <td x:num="" align="right">66</td> <td x:num="" align="right">58.36</td> <td x:num="16.975999999999999" align="right">16.976</td> <td x:num="" align="right">51.37</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3673</td> <td>
</td> <td x:num="" align="right">66</td> <td x:num="" align="right">59.55</td> <td x:num="16.686" align="right">16.686</td> <td x:num="" align="right">51.37</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3703</td> <td>
</td> <td x:num="" align="right">66</td> <td x:num="" align="right">60.03</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">51.37</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3790</td> <td>
</td> <td x:num="" align="right">70</td> <td x:num="" align="right">61.45</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">50.98</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3788</td> <td>
</td> <td x:num="" align="right">70</td> <td x:num="" align="right">62.23</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">50.98</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3818</td> <td>
</td> <td x:num="" align="right">70</td> <td x:num="" align="right">61.09</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">50.59</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3890</td> <td>
</td> <td x:num="" align="right">70</td> <td x:num="" align="right">63.07</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">50.98</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3893</td> <td>
</td> <td x:num="" align="right">71</td> <td x:num="" align="right">63.12</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">51.37</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3925</td> <td>
</td> <td x:num="" align="right">71</td> <td x:num="" align="right">63.64</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">51.76</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">3963</td> <td>
</td> <td x:num="" align="right">71</td> <td x:num="" align="right">64.25</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">51.37</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4030</td> <td>
</td> <td x:num="" align="right">74</td> <td x:num="" align="right">65.34</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">51.76</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4058</td> <td>
</td> <td x:num="" align="right">74</td> <td x:num="" align="right">64.92</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">51.76</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4089</td> <td>
</td> <td x:num="" align="right">74</td> <td x:num="" align="right">65.42</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">51.76</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4122</td> <td>
</td> <td x:num="" align="right">74</td> <td x:num="" align="right">65.96</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">51.76</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4165</td> <td>
</td> <td x:num="" align="right">76</td> <td x:num="" align="right">66.64</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">52.16</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4163</td> <td>
</td> <td x:num="" align="right">76</td> <td x:num="" align="right">66.61</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">52.16</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4192</td> <td>
</td> <td x:num="" align="right">76</td> <td x:num="" align="right">67.96</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">52.16</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4220</td> <td>
</td> <td x:num="" align="right">76</td> <td x:num="" align="right">68.42</td> <td x:num="16.541" align="right">16.541</td> <td x:num="" align="right">52.16</td> <td x:num="" align="right">100</td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:num="" align="right" height="17">4289</td> <td>
</td> <td x:num="" align="right">79</td> <td x:num="" align="right">69.53</td> <td x:num="16.396000000000001" align="right">16.396</td> <td x:num="" align="right">52.55</td> <td x:num="" align="right">100</td> </tr> </tbody></table>
Personally I don't think your fuel pump is maxing out. I think your ECU is tranmitting a rounded up value.
Look at the numbers for the fuel pump - they're only in 3rds - 33.3%, 66.6%, and 100% (dare I guess more like 99.9%?).
Something tells me those aren't the actual duty cycles of your fuel pump - the ECU only has the ability to show 1/3 increments - so perhaps anything above 66.6% is rounded up to 99.9% (or 100).
As for the Boost, I would try the LWG map
You seem to be ok. Your ecu is not pulling timing which would be a good indicator that your running too much boost, timing, etc. A log of the KC (knock correction) would help in analyzing how happy your ecu is with your car as well. As with any car, during cooler weather you will see higher boost due to the denser air and in the summer your numbers should go back to +/_ 16.5. For example on my OTS stage2 map I would see around 18 when it was below 60* out and in the summer +/_ 17.5 was typical. You should be ok, if your timing was decreasing at all after you hit the 17+psi mark then that would give cause for concern but everything seems to be ok from your logs. As for the Fuel pump duty, it will be at 100% when ever you go WOT. It just means that your ecu is telling the pump that you are at WOT and is sending that voltage to the pump. After it hits the ecu, more or less fuel is pulled to the injectors. You injector duty cycles looks ok (you are not maxing them out) as will be typical when you hit stage2. If you are still concerned you can flash in the LWG realtime map for the winter and flash back to the regular map when warmer weather comes around. Hope that helps, let me know if you got anymore questions.
Discussion Starter · #14 ·
How do I decifer the Knock correction log? higher or lower means what exactly? Is there a way to meansure a/f off the log? or a sign of wether or not im running lean?
1 - 15 of 15 Posts
