This is my Lightning Red 2015 Subaru STi Limited with Navigation and Harman/Kardon Sound System. I bought it in 2019. It is my 3rd STi. The others I modified myself. This one was mostly done by P & L Motorsport in Lisle, IL.
This where I stand right now in my build. I am taking a break from the cash bleed until Spring. I need to recover!
This STi was bone stock until May of this year(2021) when I decided to finally modify it. It was stock until 35K miles on ODO.
I tuned it to be quick, reliable and safe. P & L Motorsports in Lisle, IL did all the installation, calibration and tuning so the mods work well together to keep the engine safe.
Dyno tuning was then done by JRTuned of Prime Motoring as well as follow up adjustments by P & L.
I chose a conservative approach. Cylinder 4 GETADOM Tune Cooling Kit and IAG Competition AOS were both installed. A larger intercooler and upgraded fuel and air components were also installed.
The exhaust system from engine to tailpipe is new. I went with Equal Length Headers custom made by P & L.
My power numbers are not off the charts but the ecu has not thrown a single code since everything was installed, tuned and adjusted. It had not prior to the mods either.
I have two trunks: the winged(stock set up) and the wingless.
I replaced the stock tires with Michelin Pilot Sport 4Ss at 39,500 miles. They are great tires with outstanding grip and a softer sidewall for more ride comfort.
I am still running the stock BBS Forged Limited Diamond Black wheels.
I installed the Cobb Accessport V3. JRTuned and P & L did the tuning on the dyno. 3 sessions so far.
The Accessport mounts on the left side dash top in the air vent. I bought the plastic replacement piece so the cable runs behind the dash and out of sight. It is pretty slick.
The internals of the engine are stock.
Mods:
Cobb Tuning SF Intake and Airbox
P & L Motorsports Equal Length Headers
Stock location Up-pipe
P & L Motorsport Catted 3" Downpipe
Grimmspeed Adaptors
Invidia Q300 SS Twin Outlet Rolled Tip 3" Catback
Cobb Tuning TD05H-20G-8 (20G, for short) with Internal Wastegate
HOA 3 Port Boost Control Solenoid
Perrin Turbo Inlet Hose in Black
Perrin Top Mounted Intercooler (Largest Top Mount they produce)
P & L Top Feed TGV Deletes in Black
P & L Subaru Top Feed Fuel Rail and Line Kit.
-6 PTFE Fuel Lines and Black Fuel Rails
AEM 3.5 Bar Map (50 PSIA Sensor Kit)
AEM E85 Fuel Pump 340 LPH
P & L MS Air Pump Block Off Plate Kit
Injector Dynamics USCAR-Denso PnP Adaptor
Injector Dynamics Fuel Injectors Top Feed 1300cc
IAG Air Oil Separator Competition Series (Black Wrinkle Finish)
Getadom Tune Cylinder 4 Chamber Cooling System
Killer B Motorsport Oil Pick Up Tube
Killer B Oil Pan Windage Tray Baffle Mod
Mobil 1 Synthetic up to 35K miles and Motul 8100 5W40 from then onward.
Subaru OEM Oil Filter
Cusco Lateral Control Arms Rear
New Subaru OEM Rubber Top Mounts on all 4 corners
Bilstein GTWorx Shock Combo Package from Racecomp Engineering(20mm lowering)
Kartboy Short Shifter & Bushing Kit
Ferrodo DS 2500 Front/Rear Pads (changed at 39,500)
Power Output
June 2021 on Dyno-Jet (4 wheel) @ 90 Degree Fahrenheit 80% Humidity
93 Octane Tune
353.23 WHP
341.89
Mods:
Grimmspeed Adaptors
Power Output
93 Octane Tune
353.23 WHP
341.89
