*****KW,ST,Tein,H&R,Cusco,AirLift,Eibach,Apexi,Bil stein @ Prime Motoring*****
1346 Views 1 Reply 1 Participant Last post by  Prime Motoring
13
Here at Prime Motoring we have a massive selection of Suspension components to choose from. If you are looking for coilover systems, lowering springs, anti-roll bars, bushings, control arms etc etc, we are the place to go.
We will match or beat anyone's pricing on the internet and for local customers, we offer discounted installation rates for those who purchase their suspension components through us. Contact us today and we will beat anyone's advertised pricing!!!
KW
KW V1 - $1599.99 SHIPPED
The Variant 1 Coil-Over is an ideal entry-level system for drivers who like to control the height settings of their vehicle via KW's optimum pre-set damper settings for the ultimate balance between sporty driving, comfort and safety.
KW V3 - $2799.99 SHIPPED
State-of-the-art motorsport technology for proven performance on the streets. The independently adjustable compression and rebound damping allows for custom driving set-ups. The exclusive KW patented system has dual-level valves to provide the adjustment of the rebound damping (comfort) and the compression damping (driving dynamics) in the low-speed range. High-speed settings for driving comfort are preset by KW engineers.
Independently adjustable damping technology (rebound and compression damping)
"inox-line" stainless steel technology*
Individual height adjustment
Infinitely adjustable rebound damping
14-level adjustable compression damping
Unique, independently functioning damping power adjustment
TÜV-tested adjustment parameters
High-quality components for long life
Comprehensive documentation for ease of use
KW Clubsport - $2999.99 SHIPPED
Originally developed for European customers driving at the Nordschleife track in Germany, the KW Clubsport Coil-Overs are for customers who demand a better handling car during track day events, but also require a setup that can be used every day. The suspension settings can be adjusted to meet the requirements of your tires and the intended use and can be combined with the independently adjustable rebound and compression damping technology to allow a suspension setup based on vehicle load, tire characteristics and different track conditions.
KW Clubsport ensures excellent handling, performance, agility and improved lap times.
Height adjustable coil-overs
Performance setup for the racetrack
Independently adjustable, low speed, compression and rebound forces
High performance linear race springs
"inox-line" stainless steel damper bodies
Optional racing top mounts available for some applications
TUV approval possible depending on specification
Tein
Street Basis - $912 SHIPPED
The Street Basis damper is the evolution of the popular BASIC coilover. Developed to provide a sporty ride feeling and aggressive stance. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Vehicle ride height is adjustable via the ZT coated threaded sleeve. Updated internal components and external coatings increase durability and product life. Street Basis dampers are great for daily driving and spirited driving for all types of drivers. Made in Japan under strict quality control standards and developed by highly trained suspension engineers.
Tein Street Flex - $1490 SHIPPED
The Street Flex damper is the evolution of their popular Type Flex coilover. Developed to provide the ultimate balance of comfort and performance for both street driving and circuit use, along with wide-range damping force adjustment using their new Advance Needle technology and new damper valving specs, giving the driver a much more noticeable feel in damping force change and controllability. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Full-length adjustability offers separate spring preload and ride height adjustment. Updated internal components and external coatings increase durability and product life. Includes Pillowball Upper Mounts (camber adjustable for strut type applications) and is compatible with the EDFC and EDFC Active systems.
MONO FLEX - $2185 SHIPPED
The MONO FLEX coilover kit has been developed for entry-level competition motorsports and advanced street driving. Features include 16-way damping force adjustability (combined compression and rebound), a mono-tube internal design, pillowball upper mounts, and EDFC compatibility. There are independent adjustments for ride-height and spring pre-load settings for increased suspension tuning. The new Mono Flex also includes TEIN's latest technological innovation, Micro Speed Valving (MSV) system, which allows the driver to feel a greater difference in damping force adjustments. Designed and developed for consumers seeking aggressive handling on the street and at the track.
SUPER RACING - $3467 SHIPPED
Developed from actual competition, TEIN was able to create a fully adjustable damper that can be easily tuned for any track and weather conditions. Super Racing Dampers utilize a full-length adjustment system to allow shock length and spring pre-load to be adjusted independently. Separate 16 - way adjustments for compression and rebound damping enable the user to fine tune for any situation. TEIN has incorporated both camber and caster adjustment into the front pillow ball upper mounts for strut type vehicles. External reservoirs on SA type dampers allow for added oil capacity. Designed and tested for circuit use by advanced and professional drivers who are seeking complete damper tuning capability.
CUSCO
Zero-3 Pillow F+R - $2976.30
A coilover suspension designed for use on radial tires that features a wide array of settings from daily driving to circuit use. Provides maximum stability on bumpy roads, as well as smooth operation in any given condition.
Zero-3X Pillow F+R - $5016.50
It's coil over kit which developed to make up time on 1/100, 1/1000 level. It has newly designed mono-tube shock absorber with 24 steps damping force adjustment (3way 24 steps damping force adjustment with reservoir for ZERO3X)..
Putting "Carrosser works technology" which has been built through long time experience on motorsport, this is flagship model item.
BILSTEIN
PSS9 B16 - $3500 SHIPPED
Increase the looks and performance of your Subaru WRX or STI with a Bilstein B16 system. This system features high quality monotube gas shocks with precise compression and rebound settings (from comfort to competition) along with application specific, progressive rate coil springs. The Bilstein B16 system allows you to set your car’s ride height for your desired look and performance handling characteristics. The solid aluminum spring seat and lock nut allow for precise adjustment of the vehicle’s ride height. Ride height adjustments can be easily made on the vehicle without removing the suspension. Enjoy your improved safety and sportiness through added traction and enhanced stability. The B16 PSS setup allows you to dial through the 9 damping settings to fine tune ride and handling characteristics, have your Subaru perform exactly how you want!
TANABE
Sustec Pro Five - $$1691 SHIPPED
Sustec Pro Z40 - $2080.50 SHIPPED
1 - 2 of 2 Posts
Re: *****KW,ST,Tein,H&R,Cusco,AirLift,Eibach,Apexi,Bil stein @ Prime Motoring*****
Bump!
1 - 2 of 2 Posts
