2 questions:
1. Was the header brand new when swaintech coated it?
2. Is it the white lightning coating?
Anyway, that sucks to hear. Wrap will help with the heat, but it shortens the life of the metal considerably. I would at least put some gold foil tape, etc. on the timing cover problem areas and fan shroud.
An actual heat shield will be even better. I'm not sure exactly what it's called, but there's a bendable/formable bulk heat shield available for custom applications. You see the stuff underneath a lot of high end European cars, and I think APS uses it for their heat shield kit on the split pulse manifold.
I had a hard time finding it searching around. This is really all I could find: Heat shield for cars, exhausts, turbos, catalytic converters . You can buy a sheet, cut to shape, and wrap around the manifold securing it with metal header wrap ties.
