Car is a 2006 STi.
engine:
Iag stage 2 tuff shortblock.
oem heads
Arp head studs
Tomei equal length headers
Tial 38mm ewg
Invidia downpipe
Invidia n1 “race” cat back
Ks tech big maf 3" intake.
agency power hard 3” inlet
Spearco big tmic
3 port ebcs
4 bar (I think) map sensor
Mach v tgv deletes (pinned oem housing)
Dw 850cc injectors
Dw 300 fuel pump
Iag air oil separator
Mishimoto external oil cooler
Killer b pickup/baffle
oem 11mm oil pump
csf radiator
Alluminati upper coolant expansion tank
Killer b coolant line elbow (can’t remember the name of this)
Beatrush Motor Mounts
Group N Trans mount
Agency Power Pitch Stop Mount
Blouch 20g xtr turbo. 3” inlet. 8cm hotside.
Perrin Radiator shroud
Perrin Alternator cover
Perrin Battery tie down
Transmission:
ACT HD Clutch kit
OEM Flywheel
TiC holy shift bushing kit
TiC/Kartboy Tallboy shifter with 3" extension
Suspension:
Cygnus x1 Motorsports coilovers. Custom valved. Hyperco springs 8k (448lb) rear 9k (504lb) front.
whiteline roll center kit
Whiteline 24mm sway bars (front and rear)
Kartboy endlinks
Rear subframe lockdown bolts
I feel like there’s more but I genuinely can’t remember at the moment.
brakes:
Blank rotors
Hawk hp+ pads (soon to be replaced with somthing pads)
Motul dot4 fluid (soon to be replaced with rbf)
Mach v stainless lines
interior:
Defi oil temp. Oil pressure and boost/vacuum gauge.
prosport (I think) wideband afr
Gauge pod signed by tanner foust and Scott speed.
exterior:
Itchiba 15mm wheel spacers
Oem wheels sanded to bare aluminum and Clear coated.
tune by Sean at speedytunes
all in all, the last dyno made 377whp/401wtq. However, I have returned it since then cause it didn’t make that power after it got off the dyno because of the tune Cleo at Iag made. The max wgdc table wasn’t changed on adjustments and by the time summer came it was down 3.5psi. I only had Cleo tune it to keep the warranty on the Iag block. The minute the warranty was up speedytunes tuned it. And it’s been running flawlessly ever since.if i had to guess, currently i'm likely in the 365whp/390wtq range
