1 - 10 of 10 Posts
Hey all, I just got my 06 STI back from the alignment shop after installing a set of Tanabe GF 210s. Here are the results:
Front Left Right
Camber -.5 -.7
Caster 4.5 4.4
Toe -.01 -.02
Rear
Camber -1.7 -1.2
Toe .03 .00
whaddya think? Is it normal for them to leave it with minimal defferences between the sides like this? I asked them to max out the camber and the rest was up to them.
thanks to all who helped with info while I was installing the springs!
Ryan
Discussion Starter · #4 ·
well, I am not sure how I feel about the alignment, I feel like the tires are the weak part of the car's handling right now. I am running Pirelli PZero Nero's 225/45/17 and compared to the stock RE070s they are squishy as hell.
I have only taken a few hard turns but the feeling is just as if the tires got a little less squishy.
I think to really feel the difference I will need to go to some stiffer tires.
SPAZEGUN: thanks for your help with my install!
Discussion Starter · #6 ·
No I don't have the before #s. I had just put springs in and didn't bother putting the alignment bolts in at a certain angle. I think that Camber plates will be somewhere in my future. I think that I am happy with the rears though.
Discussion Starter · #8 ·
^ Yup, what I told him was to max out the front negative camber. Those were the only instructions that I gave him. The place is called "Wheel Works" and I think it's a pretty big chain (not sure though) the guys seem pretty competant there. They are a little overpriced compared to tirerack.com, but they usually have what I want in stock and will do work the same day. Price you pay for convenience I guess.
after all was said and done he said that was the max they could crank out of the front.
Did I read that right that you want less negative camber in the rear? our rears are not really "adjustable" correct?
Correct, but you can get 0.1-0.3 deg adjustment with the right amount of "persuation." You definitely want less camber in the rear in relation to the front, especially for our understeering cars.
1 - 10 of 10 Posts
