Thanks! They are 18x8.5 et45 w/245/45-18 Conti DSW's.Looking clean! What size Enkei’s are you running? I’m considering my stock wheels with bronze TSV’s. Thanks!
Pardon the late response, appreciate the info! I’m also strongly considering the 8.5“ width versus the 9.5” - was there anything specific that drove you to 8.5” over the 9.5”? Do they fit pretty flush/did you throw any spacers on? Thanks again!Thanks! They are 18x8.5 et45 w/245/45-18 Conti DSW's.
I went with 8.5" as this is my daily and see no track days with the goal of getting a taller tire (for better ride, venturing on dirt roads, and dealing with potholes) without causing issues. A 245/45-18 is an inch taller than the stock set up which changes the final gear ratio and throws off the speedo. I'm not running spacers and it does not sit flush, I'd say a 5mm spacer would make it flush. If on-road/track performance and handling is your primary goal I'd go 9.5. I also think 9.5" wheel with a 265/35 tires looks better on a wheel with a et38-42 offset. Hope this helps!Pardon the late response, appreciate the info! I’m also strongly considering the 8.5“ width versus the 9.5” - was there anything specific that drove you to 8.5” over the 9.5”? Do they fit pretty flush/did you throw any spacers on? Thanks again!
coilovers lol. honestly you can keep pretty close to stock ride height on coils, it doesnt have to be slammed. but if you get a set that is valved to your specs (talk to cygnus performance, theirs are made by fortune auto and still hold fortunes warranty), you'll have a set that rides nice and still handles way better than stock.Mentally debating on leaving the suspension stock or lowing it a bit with a nice set of coilovers.
I'm going to transition this car from my daily driver to a weekend/track toy in about 2 years, so I'm trying do some things now that I can enjoy while maintaining it's daily drivability, but take advantage of when it's becomes a weekend toy.coilovers lol. honestly you can keep pretty close to stock ride height on coils, it doesnt have to be slammed. but if you get a set that is valved to your specs (talk to cygnus performance, theirs are made by fortune auto and still hold fortunes warranty), you'll have a set that rides nice and still handles way better than stock.
it will be. but it's not super hard. the good ride/handling will all be in the valving. yes i do vote cygnus (unless you have a HUGE budget lol). but most people dont have that type of budget. the cygnus setup will be custom valved for your car/driving type/spring rate. and you'll be able to go up/down i think 2kg in spring rate (cant remember the lb conversion). I think dan actually bought or has some ownership with a coil brand now, cant remember which. but yes, i have a glowing review for the cygnus x1 coils lol. love mine. and i typically set height with as low as i can get it functionally. I have some gap, which i dont mind. but nothing too crazy on mine. they may end up going up a tad when i step up to 18s. i guess time will tell for that.I'm going to transition this car from my daily driver to a weekend/track toy in about 2 years, so I'm trying do some things now that I can enjoy while maintaining it's daily drivability, but take advantage of when it's becomes a weekend toy.
So coil overs seems like the next logical step, maybe a rear sway bar too. I was talking to Dan at Mach V a few months back and I believe he was suggesting the GTWORX Trophy Cup's (I honestly can't remember now). However, I've been eyeing the Cygnus X-1 as they seem to have plenty of glowing reviews (I believe from you too).
I definitely don't want to slam it, maybe just .5" as I gained a .5" when I put the taller tires on. I'm mainly concerned with having a good ride, handling, and I guess adjustability with the damper and camber (for future track use). I currently know zero about setting up track suspension, but assume this will be needed.
Nice thanks for sharing! I have a 2021 WRB and just feels like I'm making a mistake if I get rid of the wing on the last year WRB STI if I ever decide to sell. lol I saw TX STIG do similar to your method: Exterior - Wing Delete CompleteI use Vinyl that I cut into circles. A little janky and not the cleanest looking solution, but it works. I've been though a bunch of 3M Vinyl trying to match the CWP, but I haven't found an exact match. As seen in the photo below at certain angles it's not too noticeable and very noticeable at other angles.
I'm amazed after all these years nobody has made some type of kit to delete the wing. I even thought about contacting APR about buying wing mounts and doing something with those...That seems like a good solution for being able to swap back and forth. Too bad someone doesn’t make paint matched rubber grommets that you can pop in and out!! Thanks for the idea!
Thanks for the info! I see that Dan has his own branded springs, he also seems to closely work with the folks at RCE. I don't really want to spend more than 2K on the coilovers, which seems to give me plenty of good options. Geoff at cygnus seems awesome and has been more than helpful when interacting with me. I was initially looking at the "Comfort Editions" but I think I want to get into track stuff down the road now.it will be. but it's not super hard. the good ride/handling will all be in the valving. yes i do vote cygnus (unless you have a HUGE budget lol). but most people dont have that type of budget. the cygnus setup will be custom valved for your car/driving type/spring rate. and you'll be able to go up/down i think 2kg in spring rate (cant remember the lb conversion). I think dan actually bought or has some ownership with a coil brand now, cant remember which. but yes, i have a glowing review for the cygnus x1 coils lol. love mine. and i typically set height with as low as i can get it functionally. I have some gap, which i dont mind. but nothing too crazy on mine. they may end up going up a tad when i step up to 18s. i guess time will tell for that.
Think I'm just gonna hunt for some blue vinyl and do the same. Garage kept anyway, so not a huge risk of water intrusion.
Given how popular STI wing swaps are, I also wondered why someone hasn't made a simple delete kit also, you'd think you could integrate several styles of lip/duck bill spoilers that utilize the factory holes.I'm amazed after all these years nobody has made some type of kit to delete the wing. I even thought about contacting APR about buying wing mounts and doing something with those...
i think RCE may have been what i was thinking of. From what i have heard, they are good, but admittedly i dont know much.Thanks for the info! I see that Dan has his own branded springs, he also seems to closely work with the folks at RCE. I don't really want to spend more than 2K on the coilovers, which seems to give me plenty of good options. Geoff at cygnus seems awesome and has been more than helpful when interacting with me. I was initially looking at the "Comfort Editions" but I think I want to get into track stuff down the road now.
🤣STI Overland Edition...Subaru might actually be onboard with that one.A trunk rack came to mind for me. Great place to strap camping gear or something on.
What's your thoughts on the 60mm Hydraulic Spring Perches that they offer, worth it? I just saw this posted their IG which kinda sucks, "Unfortunately like everything else in the world our coilovers will soon cost a lot more money. In a little over a week pricing will have to go up by HUNDREDS of dollars. This is something we have no control over. Our suppliers are raising our costs. Aluminum, steel, shipping, manufacturing and everything else has been skyrocketing."i think RCE may have been what i was thinking of. From what i have heard, they are good, but admittedly i dont know much.
for reference, my GD STi has Cygnus X1 Motorsports edition, Hyperco springs 8k (448lb) rear 9k (504lb) front. These are heavier, but they ride better than my past two setups, WAYYYYYY better than my flatout suspension coils that had 7k front and 5k rear, those rode like complete dog shit. and then they were better slightly (comfort wise) over my old tein coils (i THINK they were flex coils, not 100% sure). and those also had 7k front and 5k rear springs. i'm amazed at the valving geoff at cygnus put in, these things ride so much better than i ever imagined, especially with the heavier springs. so they will still be comfortable while performing super well (not fully dialed in they were outperforming my old flatout setup on trackcross tracks, never used the teins for racing)
well yeah. Prices going up sucks. Yay inflation. Which is crap gov spending causing it. But IdigressWhat's your thoughts on the 60mm Hydraulic Spring Perches that they offer, worth it? I just saw this posted their IG which kinda sucks, "Unfortunately like everything else in the world our coilovers will soon cost a lot more money. In a little over a week pricing will have to go up by HUNDREDS of dollars. This is something we have no control over. Our suppliers are raising our costs. Aluminum, steel, shipping, manufacturing and everything else has been skyrocketing."
