1 - 20 of 20 Posts
OK, I installed my WRX Invidia downpipe on the STi, had to remove the transmission bracket because it wouldnt like up. Stripped one turbo stud, otherwise it was a smooth install.
Now, after 45mins of hard driving I got the CEL and the cruie light is blinking. Any ideas?? (I did intall the WRX CEL resistor mod)
Check your vacuum lines, I think that is what is causing your blinking CEL.
I have the same downpipe, but I re-welded the bracket so that it lines up.
I've read that the resistor mod wont work on any 2004 Imprezas.
Discussion Starter · #4 ·
I scanned the ECU and it had the P0139 code. O2 Sensor CKT Slow response (Bank 1 sensor 2)
Cleared the code and it came right back. I will look at the vacuum lines to be sure as well. Maybe I'll pull hte resistor out and see if that helps.
How do youlike the car with the DP??? I am not wild about the extra turbo and BOV noise I am getting with the airinx intake, but the extra power from the two mods sure is nice :D
OK, I finally pulled out the resistor mod and the CEl went away.
for a while. Its back now. I am going to put the stock air box back in to see if it is the intake causing ig. will update maybe tomorrow.
The rise of EVOKLR ;-)
So???? What is going on w/ it now?
Discussion Starter · #8 ·
CEl and blinking cruise light are now my constant driving companions. :(
I'm going to like the full 3" high flow system a friend of mine is fabricating :D
Discussion Starter · #9 ·
another update. I think the ECU has "learned" the catless system because the CEL is now out with no ECU resets. We'll see how long it stays out.
G
I have a cel fix i made, its being tested right now i have over 150 miles and no lights. Also threw one on an 03 wrx so i can see how it works there also, both cars are running Turboxs . My STi is catless and the Wrx isnt. I will keep you posted to how it works. PM me if you have any Questions
Kenny
It will work better but will not solve thr problem completely. I have to use a special adaptor to solve the issue on my Godspeed downpipes. Works fine on the STi.
Where does this wire go?
So...what did the fix for P0139 end up being? Mine just started flashing that one, even though I've had the Godspeed downpipe and XXTuning header-uppipe kit on for quite some time now.
RN
Just do the mechanical fix.
Get the "Help" brand spark plug anti fowlers (part no 42009). Drill one out with a 1/2" bit and screw them together. Search nasioc or this site for the fix. No need to weld stuff.
1 - 20 of 20 Posts
