Has anyone heard of what we're supposed to do with the intercooler water spray reservoir in the winter? I know the manual says to only fill it halfway to allow for freezing, but isn't it the "freezing" that's the problem? That little plastic reservoir will crack for sure...won't it? I wonder if I just empty it out before it gets real cold, and make sure to bleed all the remaining water out if the line, if that will solve the problem. As many of you probably live in warmer climates, this may not be a problem. However, this is something I think I need to think about.
