1 - 20 of 940 Posts
Shop located in Escondido. Full fabrication services available. Specializing in Subarus. No job too big or small.
Address is:
1948 Don Lee Place, Suite 8
Escondido, CA 92029
Check us out of Facebook:
Infamous Performance | Facebook
Check us out on Yelp:
Infamous Performance and Tuning - 26 Reviews - Auto Repair - 1948 Don Lee Pl, Escondido, Escondido, CA - Phone Number - Yelp
Phone: 760-781-1126
email: [email protected]
Please call for appointments.
For custom work we charge $100 per hour plus materials. For standard things we will quote a price.
Some basics we get lots of request for;
Exhaust Install Pricing (Labor)
Headers $175
Headers Back (Headers, Uppipe, Downpipe, Axleback) $450
Headers & Uppipe (Headers, Uppipe & Downpipe Only) $425
Uppipe (Uppipe, Downpipe) $350
Uppipe Back (Uppipe, Downpipe, Midpipe & Axleback) $450
Downpipe Back (Downpipe, Midpipe & Axleback) $250
Downpipe (Downpipe) $200
Catback/Axleback $75
Hardened Exhaust Hangers $75
*Prices based on stock vehicles in good working condition and standard replacement parts (no major rust, broken bolts, etc) Non-Standard installs will be billed at our regular hourly rate.
Turbo Install Pricing (Labor)
Turbo/Injectors/Fuel Pump (W/No Air Pump and Side Feed Injectors) $800
Turbo/Injectors/Fuel Pump (W/Air Pump and Top Feed Injectors) $900
Turbo (Bolt in) $400
Injectors (W/No Air Pump and Side Feed Injectors) $300
Injectors (W/Air Pump and Top Feed Injectors) $400
Fuel Pump $100-125
Mounts & Bushings Install Pricing (Labor Only)
Motor Mounts $200
Transmission Mount $100
Anti-Lift Kit $225
Front Lower Control Arm Rear Bushings (Legacy '05+, Impreza '08+) $225
Front Lower Control Arm Inner & Rear Bushings (Legacy '05+, Impreza '08+) $225
Front Roll Center Kit (Legacy '05+, Impreza '08+) $175
Front LCA Bushings & Roll Center Kit (Legacy '05+, Impreza '08+) $350
Steering Rack Bushings $200
Rear Subframe Bushings $150
Rear Differential Locking Bolts $100
Rear Differential Mount Bushings $200
Short Shifter (5MT) $100
Short Shifter (6MT) $175
Short Shifter w/Bushings (5MT) $150
Short Shifter w/Bushings (6MT) $205
*Prices based on stock vehicles in good working condition (no major rust, broken bolts, etc)
Electronics Install Pricing
Electronic Boost Gauge $200
EGT Gauge $225
A/F Gauge $200
Oil Pressure/Temp Gauge (In Block, only avail on certain models) $200
Oil Pressure/Temp Gauge (Filter Style) $175
Electronic Boost Controller Grimmspeed Style $75
Hella Horns $200
Hella Horns(Bumper Removal Required) $250
Services Included in our 30K Mile Service
Replacement of:
Coolant (Subaru Long Life) (Coolant Conditioner added on NA Cars)
Brake Fluid (Full Flush with ATE Type 200 or Standard Fluid)
Transmission Fluid (Subaru HP or Subaru ATF)
Front and Rear Diffy Fluid (Subaru HP)
Oil Change (Motul 8100 X-clean, Conventional – Subaru Filter)
Fuel Filter (if applicable)
Air Filter
Rotate Tires
NGK Spark Plugs (Non-Turbo Cars)
ACC Belts (Except H6 and 08+ WRX)
Clutch Fluid
Checks on: Brakes, Parking brake, Clutch, Suspension, Fuel lines, Exhaust
Pricing:
Turbo
30k Using Conventional Engine Oil & Subaru Oil Filter $485
30k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $530
*On 09+ Impreza/Legacy (and cars with Subaru Super Long Life Coolant) $50 discount due to the coolant change interval being 100k miles.
Non-Turbo – H6 add $70 (serpentine belt, oil)
30k Using Conventional Engine Oil & Subaru Oil Filter $440
30k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $475
*On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Type), cost for AT cars is $45 Extra due to Fluid and Filter costs.
**On Forester $20 extra due to plug placement.
Services Included in our 60K Mile Service
Replacement of:
Air Filter
Rotate Tires
NGK Spark Plugs
Clutch Fluid
Pricing:
Non-Turbo Engines – H6 add $70 (serpentine belt, oil)
60k Using Conventional Engine Oil & Subaru Oil Filter $525
60k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $570
Turbo H4
60k Using Conventional Engine Oil & Subaru Oil Filter $600
60k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $650
*On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Filter Type), cost for AT cars is $45 Extra due to Fluid and Filter costs.
***On H6 Models $35 extra due to plug placement and quantity.
Services Included in our 90k Mile Service
Replacement of:
Air Filter
Rotate Tires
Clutch Fluid
Pricing:
Turbo
90k Using Conventional Engine Oil & Subaru Oil Filter $485
90k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $530
90k Using Conventional Engine Oil & Subaru Oil Filter $440
90k Using Motul 8100 X-clean Engine Oil & Subaru Oil Filter $475
Services Included in our Timing Belt Service
Replacement of:
Timing Belt
Timing Belt Tensioner
Timing Belt Pulleys
Water Pump
Thermostat
Coolant Flush
Timing Belt Service Pricing:
Turbo
Timing Belt Service $775
Timing Belt Service (when combined with a 90k service) $725
Non-Turbo
Timing Belt Service $745
Timing Belt Service (when combined with a 90k service) $695
Oil Changes
Motul 8100 X-clean 5w30 w/Subaru Oil Filter $90
Standard Conventional Oil 5w30 w/Oil Filter $50
Bring your own Oil/Filter Change $40
Coolant Changes
Subaru Long Life Coolant Drain/Fill $125
Subaru Super Long Life Coolant Drain/Fill (100k Blue Subaru Fluid) $165
Gear & Transmission Changes (labor only)
Subaru 5MT Front Diff, Trans - Subaru HP $75
Subaru 6MT Front Diff, Trans - Subaru HP $85
Add Rear Diff $35
Subaru 4EAT or 5EAT ATF - Subaru ATF $80
Add Front and Rear Diff $70
Add Subaru ATF Spin on Filter $10-50
BRZ/FRS 6MT Trans – Subaru HP $75
BRZ/FRS Rear Diff $45
5MT/6MT Clutch Labor
Clutch & Flywheel Labor Only $550
Add Front Diff, Trans – Subaru HP $75
5MT Flywheel resurface (single mass) $90
6MT Flywheel resurface $70
Misc Services (labor only)
AC/Alt-PS Belts (Per Belt except 08+ WRX AC) $30
Spark Plug Replacement – Turbo (4) add $25 for OBXT/Forester $200
Compression Test – Turbo (4) add $25 for OBXT/For $235
Compression Test – Non Turbo (4) $150
Spark Plug Replacement – Non Turbo (4) $100
Springs/Shocks/Struts
Springs/Struts/Shocks (Labor Only) $300
Koni Sport Struts Inserts (Labor Only) $400
Coil Over Install and ride height set $400
CV Joints/Axles/Wheel Bearings
Drive Axle w/CV Joint (Labor Only) $100
Sway Bars
Rear Sway Bar w/o Mounts (Labor Only) $100
Front Sway Bar (Impreza '02+, Legacy '05-'09) $100
Standard Engine Rebuilds
CP Forged Pistons w/Rings
King Bearings Rods
King Bearings Main
ARP head studs
11mm Sti oil pump
Timing kit w/water pump
OEM Gasket Kit
Bore/Hone w/torque plates
3 angle valve job, adjustment, resurface, cleaning of heads
Service intake AVCS gears
OEM PCV assembly
OEM T-stat
NGK plugs
OEM Coolant
Oil (10 qts Motul Break in oil)
2 x OEM Oil Filter
Labor
$6400
Brakes
Standard Fluid Flush (labor only) $70
ATE Type 200 Fluid Flush $125
ATE Fluid Flush + Stainless Steel Line install (02-07 Impreza) $225
ATE Fluid Flush + Stainless Steel Line install (08+ Impreza) $250
ATE Fluid Flush + Stainless Steel Line install (05-09 Legacy) $300
Front or Rear Pads Installed $100
Front and Rear Pads Installed $170 w/fluid flush (labor only) $220
Front Rotors and Pads Installed $200
Front and Rear Rotors and Pads $300 w/fluid flush (labor only) $350
Coolant Related Items
Radiator Replacement (Labor) $200
Accessory Related Items
Alternator (Labor Only) $100
Misc Items
Subaru Valve Cover Gaskets (Labor both sides) $400
Subaru Head Gaskets Non-Turbo SOHC Engines (Parts & Labor Estimate) ~$2,500
Subaru Head Gaskets DOHC Engines (Parts & Labor Estimate) ~$3,800
(If the Heads need reconditioning additional charges may apply)
Parking Brake Adjustment $50
Prices valid on stock vehicles in good working condition (no major rust, broken bolts, etc). Prices are labor only, materials extra (unless otherwise noted).
Discussion Starter #7 (Edited)
Re: Installs, Service, Maintanance, Repairs, Custom work, Tuning! In So Cal.
2014 Presidents Day Sale!!!
10% off all orders using promo code "Pres14" at checkout! Free shipping on all orders $299+ too!
Sale and promo code valid from 2/17/14-2/28/14.
No order minimum. No limit to times the code can be used.
Discussion Starter #13 (Edited)
Stock 2013 STi
Stage2 2012 STi.
Stock 2005 LegacyGT 5EAT.
2010 STi. Stage2. e-85.
05 LGT Wagon 5MT. 68hta 7cm hot side. e-85. Car was just switched over to e-85 on way to dyno (customer has dual maps). So, some CAN91 still present in the mix.
2013 FR-S. AT. Innovate S/C. Invidia hi flow cat down pipe. Invidia CBE.
2013 FR-S. Intake and Borla headers.
2012 STi. Built motor. Stage 2 with EWG.
2013 FR-S Full Blown Motorsports Turbo Kit.
2012 STi, built motor, AEM intake, GS TMIC, GS X-over pipe, GS up pipe, Cobb down pipe, Invidia N1, GS 3port, Perrin inlet, stock turbo and fueling, Cobb AP, 4th gear pull.
Discussion Starter #14 (Edited)
07 SpecB. Autospeed TBE, AVO TMIC, SPT Intake, AP. 6MT, 4th gear pull. CAN91. 220awhp, 253awtq.
08 SpecB. Built motor (online purchase), KStech 73mm intake, BNR 18g, DW 1000cc, PW Style TMIC, Invidia catted DP, OEM CBE. 4th gear. 91CAN. 234awhp, 265awtq.
2013 STi. Cobb DP, GS 3port, Perrin drop in. CAN91. AP. 4th gear. CAN91. 246awhp, 295awtq.
Discussion Starter #16 (Edited)
08 SpecB. Tuned by our old tuner who no longer works with us. Hope to get this car back to the shop and re-tune with Bill Knose (Delicious Tuning).
2012 STi. 91CAN and e-85. Bill Knose (Delicious Tuning).
2012 STi. Bill Knose (Delicious Tuning).
07 STi. Bill Knose (Delicious Tuning).
03 WRX. Bill Knose (Delicious Tuning).
08 LGT. Bill Knose (Delicious Tuning). Base line and Final tune.
13 STi. Bill Knose (Delicious Tuning).
12 WRX. Bill Knose (Delicious Tuning).
13 STi. Bill Knose (Delicious Tuning). Cobb OTS map (baseline), then Bills SCCA (OEM boost) map, then 18 psi (street), then 19psi (drag strip) maps.
07 LGT SpecB. Bill Knose (Delicious Tuning).
12 STi. Bill Knose (Delicious Tuning). Street map and Drag map.
06 WRX. Bill Knose (Delicious Tuning).
Discussion Starter #19
Infamous Performance is proud to announce our new partnership with Delicious Tuning!
Delicious Tuning
Bill Knose of Delicious Tuning is now offering dyno tuning services at Infamous Performance using our Mustang AWD-150-SE dyno.
About
William is a second generation computer science engineer, after his mother an aerospace and mathematician and a second generation tuner after his father who calibrated jet engines, based on EPA guidelines for fuel economy and maximum thrust levels.
William has attained a Bachelor’s degree from Saint Michaels College and graduated in 1999 with a major in Computer Science and a minor in Mathematics. In the time William graduated, he started tuning Subaru’s as one of the very first OEM custom Subaru tuners in North America. During his 13 years of tuning experience he has been involved in customizing the engine management systems in some of the most famous and well recognized vehicles of the past decade including the infamous Ken Block Gymkhana 1 and Gymkhana 2 race cars, Stephan Verdiers Formula Drift and Rally Cross race cars, Zenkai Motorsports Time Attack & Pikes Peak race cars, and of course the Crawford Performance’s Time Attack race car. His experience doesn’t stop there, he has also developed and received incredible feedback on his track tunes from the likes of Tanner Foust, Keiichi Tsuchiya and Tarzan Yamada, while applying that knowledge onto the tuned ECU’s of Dave Mirra, Travis Pastrana and Andre Lotterer (Two Time 24hr Lemans Winner).
Beyond the race cars and drivers he has worked with, William has also tuned hundreds if not thousands of daily driven and track enthusiast vehicles over his career. Not only has he tuned vehicles in North America but remotely (via the internet) around the world.
Background
Delicious Tuning, Inc. roots date back to 1999 as a company providing high end engine management performance tuning, custom product and business development, and management support for new and developing companies in the aftermarket performance industry.
William Knose is the owner and tuner at Delicious Tuning and his business background stems from I-Speed USA which was formed in 2001 as a company providing installation services, custom tuning, corporate internet presence, and they performed the first Subaru RS to WRX conversions in North America. I-Speed USA’s website and name were a well-recognized brand in the Subaru performance industry up through 2005 when it joined forces with a newcomer to the street performance world, Crawford Performance.
With an agreement to focus on building the Crawford Performance brand, I-Speed USA was purchased by Crawford in 2008. The following year the infamous Ken Block Gymkhana 1 and Gymkhana 2 videos hit the performance industry by storm. Stunning, reliable, and powerful tunes wowed Ken Block and the industry allowing the Crawford brand to become the leader in the Subaru Performance tuning industry. Being in the right place at the right time, reliable and consistent engine builds, and precise engine management tuning made for an extremely successful Gymkhana 1 and Gymkhana 2 video.
Resume of cars tuned
Ken Block - Gymkhana 1 - EcuTeK
Stephan Verdier - Formula Drift - EcuTeK
Stephan Verdier - Pikes Peak - EcuTeK
Stephan Verdier - Rally Cross - EcuTeK & Motec
Ken Block - Gymkhana 2 - Motec
Kevin Jones - Pikes Peak - EcuTeK
Jimmy Keeney - Rally America - EcuTeK
Jimmy Keeney - Rally Cross - EcuTeK
Tanner Foust - Time Attack EcuTeK
Ken Block - Gumball DC Shoes - EcuTeK
Tarzan Yamada - 850HP Time Attack Subaru - EcuTeK
Kevin Jones - La Carrera Champion - EcuTeK
Kevin Jones - One Lap of America - EcuTeK
Russ Warr - NASA Time Trials - EcuTeK
Tarzan Yamada - Long Beach Super Lap Battle - EcuTeK
Stephan Verdier - X-Games - EcuTeK & Motec
Location
Infamous Performance 1948 Don Lee Pl #8
92029 Escondido, CA United States
Phone: (760) 781-1126
33° 7' 42.096" N, 117° 7' 11.0712" W
See map: Google Maps
www.infamousperformance.net
Offering Delicious Tuning
Scheduled Custom Dyno Weekday/Weekend Trips
Custom E-Tuning with Dyno Verification
EcuTeK Master Tuner
- EcuTeK ProECU Cable Kits & Tuned Packages
- Subaru BRZ, WRX, STI, FXT, LGT
- Scion FRS
- Nissan GTR
Cobb Pro Tuner
- Subaru WRX, STI, FXT, LGT
UpRev Osiris Tuning
- Nissan 350Z, 370Z
PowerAxel Pro Tuning
- 2010-2011 Hyundai Genesis 2.0T
JEC Reflash Tuning
- 1999-2002 Impreza 2.5 RS
- 1999-2001 Impreza 2.2L
- 1999-2002 Forester 2.5L
1 - 20 of 940 Posts
