1 - 2 of 2 Posts
I just got my speaker brackets from Stephen at IA, so I figured I would hook up my speakers (put the hu in last week). I looked at a few install forums to see if there was anything special I needed to know, nope..looks pretty straight forward. To my surprise though, there are no wires for the speakers in the rear doors in my car. Am I missing something? Aren't the STi's supposed to be pre-wired? I cut the plastic to mount the speakers and I don't see any wiring...only that for the window control. wtf???
Has this happened to anyone else?
I haven't checked the fronts yet. I was planning on doing them tomorrow.
I'd appreciate your feedback...thanks!
NEVERMIND
I found them. I didn't realize they were clipped inside the frame. [/b]
wie geht es ihnen?
seems strange...however, i recall it took me a few minutes to locate the wire and adapter inside the rear door.
it's tucked in nicely behind the metal panel and the white factory adapter is secured via a push-through plastic piece into a hole in the door.
i also thought is was wiring for the window or something on first look.
something to check: near the speaker cutout, is there a small round (not square) hole with a white plastic piece portruding through it? or is the small hole empty?
can you post a pic?
1 - 2 of 2 Posts
