1 - 3 of 3 Posts
I have gotten up to where its time to screw in the oil pressure sensor, but the sensor threads are too tiny for the galley plug, do i have to buy some sort of adapter so the oil pressure sensor can screw in to the whole?
also, if i have to get an adapter fitting, can i get one that has a T configuration with the holes so i can pluf the oil temp sensor in there too, or is there a seperate spot for the oil temp sensor, and if so where is that
I have heard that the easiest way to install Oil Pressure and Oil Temp is to buy a sandwhich adapter for around $70 and plug them both into that. I am installing my gauges in two weeks and am planning on going that route. I am not 100% certain but believe the sandwhich adapter threads in where the oil filter goes and then the oil filter threads on to the adapter. I am buying a Greddy sandwhich adapter from The Tuning Factory, a vendor on these boards. I hope this helps. Hopefully somebody else will chime in that has already gone this route.
1 - 3 of 3 Posts
