1 - 20 of 20 Posts
I decided to get fuel rails to get rid of the hesitation completely.
After 3 FPR testing. I have installed the cobb kit which had the least AF correction.
When installing Fuel Rails, should i replace injectors? Or use the OEM?
I dont have an issue currently with the OEM and the car is stage 2.
What precautions and things to buy before the installation?
Thanks in advance.
I am hitting 90% IDC in the winter. But I happy with the current power levels.
But question will the injectors on my current mods increase power? Without any extra supporting mods.
Thanks for your replies I apprecite it.
If you're almost maxing out your current OEM injectors but don't plan on making much more power than now, I would just install some lower cc injectors like some 650cc or even 850cc just in case you feel like making a little more power in the future. Those injectors I mentioned would also let run just fine with your current mods. Any interest in running E85 though?
Discussion Starter #8
I dont have E85 on my region.
Thanks. Any parts require change as precaution if I am reusing the oem injectors?
The o-rings on the bottom and top of the injectors, you can get them from Subaru. Make sure to grease/lube them prior to bolting everything down.
Discussion Starter #11
Are 1000cc injector is ok for stage 2? I cannot find smaller in our local market only ID1000CC.
That's definitely not necessary, and I think you'll need a bigger fuel pump to run 1000cc. You can though, get 1000cc injectors and a DW65c pump but have stage 2 installed, so you'll essentially be at Stage 2+. You'll be in the 300 - 350hp range on 91/93 with Stage 2+.
If you don't want to be at Stage 2+, your OEM injectors will be fine.
Then if you want decent gains in power, get the 1000cc injectors and a pro-tune. You'll be safely under the breaking point of those oem pistons.
Discussion Starter #16
I will adjust he injectors in the tune and keep everything the same. I guess I will end up with the same power level.
I don't want to get intake for now.
Get the 1000cc injectors, you'll be happy with how much room you'll have for future power mods. You can run anywhere from 300hp to 450+/- with those injectors.
1 - 20 of 20 Posts
