1 - 20 of 27 Posts
Ok, well after viewing Peleg's thread of installing evo 8 seats into our sti's, i was so set on picking up leather recaro's out of a 9 and installing them. well, after 3 different sellers jerking my chain, i finally gave up and stumbled upon the new X seats. i like them as well, and (to me) they are just as comfy, plus i havent seen anyone else install these yet so i figured i could be the first. I figured i'd make a separate thread b/c the process is not the same.
What you will need:
safety glasses
gloves
some kind of respirator mask from metal debri
10,12,14,17mm sockets and wrenches
torx bit (forgot the size, i think,45)
Dremel with cut off wheels, grinders, etc
Power drill with drill bits
patience
so after buying the seats, i quickly came to realize that the sliders are VERY diffferent from the older models. take a look:
Driver seat:
you have 5 pieces you have to remove from these set of sliders, which isnt so bad because they are just held in by rivets, which i simply just cut the tops off of, pried off the bracket using a screwdriver/hammer, and then used a punch to knock the remaining piece out. ill go into detail later.
Passenger seat (these have the EVO base attached to it)
after you take off the base and other misc rubbish you dont need, you are left with four of these in each corner on the actual base along with one other bracket on one of the sliders:
see those nice welds? yep, have to cut through them. luckily there is one on each slider that is only welded on one side, which makes things a tad easier (picture above only has welds on one side of that bracket). the opposite side has welds on both.
ok, so lets rewind and start off from the beginning. i forgot to take some pictures of it, but on the passenger side it has what im assuming is the seat weight harness and you need to remove that, ill get a picture later)
1) Start by removing the sliders from the seat. both seats have 3 star bolts (forgot the exact name for em, torx?) on each side that you need to remove. see on the left side of this picture below there are two next to each other, followed by another on the other side that is screwed almost all the way out. you also should take the seat belt bolt off at this time (if your seats came with the seatbelts).
2) once removed you should be left with these pieces for each seat:
3)here is the passenger sliders unmounted from the seats. now you need to remove the slider bar.
4) the slider bar simply is snapped in place, just twist it a tad and remove it and unhinge it.
5) now you are left with this. (dont mind my nosey ass dog, lol)
6)now, time to drill. i'll only show one side as if you can tackle the passenger side you will breeze by the driver one.
i grabbed my trusty dremel and the first point of action was to cut those rivets (yeah, even the damn welded sides have them).
cut the top off like so. this will make it easy for you to pop off the bracket once you cut through the welds. be patient, they take a bit to get through them. once you do, what i did was stick a screwdriver in the spot i just cut into the weld, and hit it with a hammer to get it to separate.
once you do this, and you get the bracket off, it should look like this:
7) there is a tiny bit left of the rivet still sticking up. you would think you would be able to just use a punch and knock it out, but cut the rest of the rivet off, and you will get this:
8) now take your punch and whack just on top of what you cut off. where the rivets are on each slider is your mounting holes.
9) repeat for both sliders, removing all the brackets. you end up with this:
all that is left to do is grind down where the welds were (and on the driver side, there are two threads coming out in the middle of the slider you need to cut off) and then you are left with two clean sliders.
now repeat the same steps give or take and remove the driver side brackets on the sliders. this side is much easier like i said earlier since only the rivets are holding them in.
this is the carnage you are left with after tackling both sliders on each seat :lol:
10) re-attach the sliders to the seats.
11) your next course of action is to decide what bolts you are going to use to mount them, and what bases. you can either order custom ones from wedge giving them the correct measurements (a buddy is also putting x seats into his 08, he is ordering from wedge so i will confirm the measurements once he has it) or, you can use sparco bases (same models listed in Pelegs thread). i decided to use sparco bases because i had sparcos in my STi until these.
***something to note. make sure whatever bolt you use, will fit in between the slider pieces first. if you get a bolt that has too big a head on it, you wont be able to slide the sliders back and forth.
i had to mod my bases a tad to get them to fit, but as you can see in this picture it wasnt by much. the sparco base has two mounting locations, and the outer holes are the ones you will use for the x seats. i had to shave down a little on the each back corner on the sparco seats to get it to fit right. also, you will need to drill out the mounting holes to the appropriate size of the bolts you are using. i used a 5/16.
in this picture you can see the bolt comes up, and looks to interfere with the weld/bracket. if you shave down just a little bit, you can get the nut onto the thread without hacking up the bracket.
12) bolt the 4 corners up, add some locktite, and you are ready to mount them into the car!
13)
could have taken better shots, but you get the idea :lol:
I know i was brief, but if you have any questions, or any comments that should be added, let me know. I tried my best to take shots of everything, but once im in a groove i tend to forget haha. i will get pictures up tomorrow of them mounted in the car.
big thanks to jay_barton on Nasioc, as he gave me a pre-warning of the sliders and some tips of how to tackle this. not sure if he has a user name on here but if you do chime in with anything i might have missed.
old thread back to life,.
Is there a better "base" to choose from for a perfect fit? I have a 2005 STI too, and notice the Wedge brand use the Forester base. Is it better to use a Sparco, Wedge, or Recaro base and anyone got inputs on best pricing for this?
I used the sparco bases...I have had a few people PM me telling me that their wedge brackets were off. But, you need to provide wedge with the dimensions, so they probably didn't calculate it correctly.
I had used the wedge brackets. They suck period. While they were not off they do set the seat too high. I had to cut the tabs so I could put the seats on the lowest setting of the three height positions. The tabs would hit the floor and would require me to use the highest setting. Also had a heck of a time getting the pass. side to fit. Never thought I would get it, but once I figured out that I had to have the bracket in at almost a 90 degree angle I was able to secure it to the floor boards. As for the seats, LOVE THEM! So much better over stock and hold you in. Probably my favorite mod I have done to my car and for the price could not beat it.
8/17: looks good
The ultimate form of flattery lol
Ultimate seats in my opinion. Subaru should offer this as factory installed option..........I did ask them that back in 2007, but they don't care.
Glad to see this upgrade lives on. I loved mine back in 2007, it changed the whole driving experience.
I just acquired some Recaros from an X and was going to do the Wedge brackets since they are local, did your buddy ever get the measurements? Also, did the X airbag sensor work on his car? Curious to know if he had any wiring issues.
If you look on NASIOC there is a thread on there on the 2nd or 3rd page stating what the measurements are. As far as I know, nobody has got the airbag sensor to work... I would love for somebody to prove me wrong, becuase I have wanted to do this myself.
damn i miss my evo x seats... actually i miss my evo x... but the seats especialy... got a bride stradia for the drivers side and guess what, these arent made for 5'7 175 pound guys with a 44 inch chest... i was worried about the waist but no at 33" i was good... had the brides on for 2 days exactly... gona get set of evo x seats... thanks for this cuz i see it can be done...
Decided to take a day off soon and head over to Wedge, they said they can measure the seats in person themselves to make sure the brackets are a solid fit.
I am not bashing the wedge brackets (i got mine used may have something to do with it) but i had to wrestle around with mine for way to long. My passenger seat still has issues sliding forward and back, like its binding up, cant figure it out and dont care anymore. Do Love the ish out of the seats, makes me feel all warm and fuzzy inside when i sit in em.
I'd figure I'd let them take a look and take measurements so I don't eff it up. Seems like there aren't too many options, either Wedge or modify a Sparco base (pretty sure I'd eff that up as well). I sat I'm the seats and they are a huge improvement.
I had a hell of a time gettting the wedge bracket to work on the drivers side. I don't know to this day how I got it to work but lets just say I don't plan to ever take it out now. I also felt the wedge brackets put the seat too high and in order to lower the seat I had to cut the bracket that allows for height adjustment. Mine was hitting the floor and would not allow for the lowest setting. While I was able to just cut the bracket to get to the lowet setting I should not of had to do that. If the wedge bracket was sized for my car this should not of been an issue. Just my two cents again.
1 - 20 of 27 Posts
