Yes with larger injectors you will definitely need a new tune as they will have to be scaled according to how large they are. (This is assuming you are going with larger ones than stock.)
Ok, I figured as much... I guess I'm just more worried if I'm going to cause any problems on my way to the tuner since I'll be installing the injectors before hand and then driving there. Perhaps I should do it in the parking lot... lolYes with larger injectors you will definitely need a new tune as they will have to be scaled according to how large they are.
You arent the first person who's had to install injectors and then drive it to get it tunedOk, I figured as much... I guess I'm just more worried if I'm going to cause any problems on my way to the tuner since I'll be installing the injectors before hand and then driving there. Perhaps I should do it in the parking lot... lol
Okydokey. Thanks for the infoYou arent the first person who's had to install injectors and then drive it to get it tuned
What you can do is have the tuner e-mail you a base map scaled accordingly for those injectors. Just remember to keep out of boost range while driving there.
