1 - 20 of 97 Posts
INCREDIBLE Deals: South Bend, Clutch Masters, GrimmSpeed, ID, Kartboy, SuperPro &More
Cygnus Performance has the highest feedback rating on IWSTI because customer satisfaction has always been our number one goal. We have never tried to be the biggest vendor by compromising quality. We don't sell parts for every car under the sun. We focus on STi's and we have focused on STi's since day one. We drive STi's on a daily basis, and we modify them so we are one of the few shops that can give you first hand product advice. Our goal is to get you the best prices out there while still offering fast shipping, industry leading tech support and customer service that genuinely cares about your business. Give us the opportunity to earn your business and we will do what it takes to keep your business!
-Geoff
Owner & Founder Cygnus Performance, LLC
The best deals anywhere on South Bend Clutch!​
Find a lower shipped price and we will beat it.
South Bend Clutch makes the highest quality, most reliable single disc clutches we have ever used!
Click on clutch images for price:
CLICK TO VIEW South Bend Stage 1 Clutch Kit 04-17+ STi Part# FJK1000-HD
Torque Rating: 465 ft/lbs
Heavy duty version of the stock O. E. clutch. The Pressure Plate has an increase clamp load for extended life. The disc is dual dampened for smooth engagement and increased transmission life. Premium friction material ensures rapid heat dissipation increasing the life of the clutch.
CLICK TO VIEW South Bend Stage 2 Daily Clutch Kit 04-17+ STi Part# FJK1000-HD-O
Torque Rating: 495 ft/lbs
Stage 2 Daily: Engineered for HP modifications. This Heavy Duty Pressure Plate has an increased clamp load with little or no increase in pedal pressure. The Organic disc material has a high metal content that increases the co-efficient of friction by two times over a stock lining and increases rotational strength up to a 12,000 RPM burst point. This clutch system maintains a stock feel while offering strength and durability.
CLICK TO VIEW South Bend Stage 2 Drag Clutch Kit 04-17+ STi Part# FJK1000-HD-DXD-B
Torque Rating: 595 ft/lbs
Stage 2 Drag: Drag racing requires a Single Mass SFI approved Flywheel to be included with each kit when the original design is Dual Mass. This system features a Heavy Duty Pressure Plate modified for a puck style disc with no cushion between the linings to keep the clutch pedal travel short and quick. The puck design disc reduces rotational mass and total drive surface area while increasing pounds per square inch on the surface of the friction material. This combination minimizes inertia, accelerating the transfer of torque from the engine to the wheels. The friction material used for this race application is Graphite Impregnated Ceramic. This compound exceeded all other friction materials when testing for durability, reduced chatter, heat transfer and torque capacity. Recommended uses are drag racing, drifting and limited street.
CLICK TO VIEW South Bend Stage 2 Endurance Clutch Kit 04-17+ STi Part# FJK1000-HD-OCE
Torque Rating: 565 ft/lbs
Stage 2 Endurance: An SFI approved single mass flywheel is recommended for this application to get optimal performance. This clutch system is designed for the racing climate. The pressure plate is precision balance for vibration free operation at high RPM. The pressure plate fulcrum is altered for a positive disengagement and a quick shift. The disc is engineered with a Dual Damped design to provide accurate control when accelerating through corners. The friction material is a hybrid using a full face Feramic (Sintered Iron) lining on the flywheel side and a high metal content Organic lining on the pressure plate side. Engagement is positive yet buffered due to the high graphite content unique to Feramic facings. Recommended uses are daily and street with an emphasis on Rally and Endurance racing.
CLICK TO VIEW South Bend Stage 3 Daily Clutch Kit 04-17+ STi Part# FJK1000-SS-O
Torque Rating: 590 ft/lbs
Stage 3 Daily: Recommended for single mass flywheel (SMF) when original design is DMF. This clutch package is designed for high HP vehicles desiring a start performance similar to O.E. The pressure plate is Race Engineered (SS) and SFI approved with significant load increase over stage 1,2 pressure plates (+600-800 lbs.). Expect a pedal effort increase of 20%-25%. Discs are assembled with heat-treated wear resistant hubs; drive plates and springs for high load transfer and dependable operation. The sprung centers on the disc in conjunction with the marcel fin between the linings create a dual dampening effect that simulates O.E. start performance. A Performance Organic friction material with a high metal content increases torque and RPM capability and maintains low operating temperatures which reduces wear and glazing. Recommended usages are daily, spirited street and occasional track.
CLICK TO VIEW South Bend Stage 3 Drag Clutch Kit 04-17+ STi Part# FJK1000-SS-DXD-B
Torque Rating: 695 ft/lbs
Stage 3 Drag: Drag racing requires a Single Mass Steel Flywheel to be included with each kit when the original design is Dual Mass Flywheel. This clutch package is built to handle heavily modified cars and designed to function according to the specific needs of the 1/4 and 1/8 mile track. The pressure plate for this kit is SFI approved Race Cover engineered to disengage with less pedal travel shortening the shift time. Discs are a puck design, which reduces rotational mass and are assembled with all high carbon component pieces for maximum strength. The friction material used is Graphite impregnated Ceramic perfectly suited for drag racing because of its maximum friction co-efficient, rapid heat dissipation and abrupt engagement characteristics.Recommended uses are drag, pulling, drifting.
Torque Rating: 615 ft/lbs
Stage 3 Endurance: Recommended for single mass flywheel (SMF) when original design is DMF to achieve optimal performance. This kit uses the same Race Engineered SFI approved pressure plate as stage 3 daily package. The disc is designed for the special needs of a vehicle with circuit racing in mind. Kevlar friction material is used for its unique static to dynamic ratios of friction coefficients at high energy levels. This translates to a perfect transition from one gear to the next. Discs are assembled with only performance components and equipped with torsion springs functioning as a damper between engine and gearbox.Recommend usages are Rally, endurance race, clubsport, autocross, street and daily.
CLICK TO VIEW South Bend Stage 4 Extreme Clutch Kit 04-17+ STi Part# FJK1000-SS-X
Torque Rating: 700+ ft/lbs
Stage 4 Extreme: This is a "build to order" clutch kit intended for cars with HP modifications exceeding the stage 3 parameters. The Race Engineered pressure plate is modified for maximum plate load. The discs are puck design with sprung and un-sprung options. Friction material options include Sintered Iron and Graphite Impregnated Ceramic. Engagement characteristics can be abrupt. Hydraulic systems may need enhancing for proper clutch separation. Single mass steel SFI approved flywheels are required for safety. Torque ratings are calculated at time of ordering.
The best deals anywhere on Clutch Masters!
CLICK TO VIEW Clutch Masters FX100 Clutch Kit 04-2015+ STi Part# 15-017-HD00
Heavy duty pressure plate; steel-backed organic disc; smooth engagement. The Clutch Masters FX100 clutch is designed to be a dependable and economical alternative to Subaru's OEM replacement. The FX100 is made for the daily driven STIs with basic bolt-ons. The Clutch Masters FX100 pressure plate offers 70% more clamping force over a stock STI pressure plate. The STI Clutch Masters FX100 disc is a steel-backed organic disc with the highest quality hub assemblies available to ensure durability and driveability.
CLICK TO VIEW Clutch Masters FX200 Clutch Kit 04-2015+ STi Part# 15-017-HDKV
Heavy duty pressure plate; steel-backed Carbon-Kevlar disc; smooth engagement & extended life. The Clutch Masters FX200 is recommended for the STI with a little more than just basic bolt-ons. The FX200 offers comparable torque capacity to an FX100, but provides exceptionally smooth engagement & extended life (thanks to the Kevlar). Owners that daily drive their STI and wants quick engagement when driven enthusiastically need to look no further than the Clutch Masters FX200 kit.
CLICK TO VIEW Clutch Masters FX350 Clutch Kit 04-2015+ STi Part# 15017-HDFF
The FX350 System uses the Power Plus I Pressure Plate with Clutch Masters New Formula Button disc. This clutch is designed for the street enthusiast or weekend racer who plans to abuse their vehicle on an occasional basis and have a spirited driving style. The FX350 clutch system has a higher holding capacity than a segmented Kevlar lining without compromising the street friendly characteristic Clutch Masters is known for. For year’s enthusiast have had to compromise durability for drivability and vise versa, however with Clutch Masters New Formula button we have closed the gap between these two tradeoffs.
*All stages come as a complete kit including disc, pressure plate, throwout bearing, pilot bearing (when applicable), and alignment tool. (Individual components available upon request)
*Organic/ Kevlar/ Formula Button Clutch kits are expected and tend to have a higher life expectancy than OEM, however not guaranteed. Improper Installation, Driving style, performance upgrades, Break in procedure and light weight flywheels will effect and have a role in determining the life expectancy of the clutch kit.
CLICK TO VIEW Clutch Masters FX350 HIGH REV Clutch Kit 04-2015+ STi Part# 15017-HRFF
CLICK TO VIEW Clutch Masters FX400 4 Puck Clutch Kit 04-2015+ STi Part# 15-017-HDCB4
Heavy duty pressure plate; sprung, 4- or 6-pucked ceramic disc; quick engagement; tremendous holding power. If your STI has major upgrades and is making loads of power and/or your STI is a dedicated track car, then you should look at the FX400 clutch from Clutch Masters. You will experience harsh engagement that is not suggested for daily driven cars, but is ideal for the for aggressively driven weekend toy and track driven STI. Did we mention that engagement is harsh and pedal feel will be heavy? Clutch Masters offers the FX400 as a 4-puck or a 6-puck kit. The 6-puck kit will dissipate heat better than the 4-puck version, but the 4-puck can handle a little bit more power.
CLICK TO VIEW Clutch Masters FX400 6 Puck Clutch Kit 04-2015+ STi Part# 15-017-HDCB6
CLICK TO VIEW Clutch Masters FX500 4 Puck Clutch Kit 04-2015+ STi Part# 15-017-HDB4
FX500 clutch kits offer a holding capacity of 200-400% over stock and utilize a solid hub for fast engagement. This clutch is not recommended for STIs that see any street driving. It is a unsprung style disc that will yield an extremely hard and quick clutch engagement with no slippage. This is the perfect clutch for full race or drag modified STIs that have upgraded gear sets only. This kit would be nearly impossible to drive on the street, so please be sure you do not purchase this kit with daily driving intentions. The 6-puck kit will dissipate heat better than the 4-puck version, but the 4-puck can handle a little bit more power.
Please note this clutch is 4 puck even though 6 puck is pictured. This is a solid hub clutch. It will be extremely harsh for street driving.
CLICK TO VIEW Clutch Masters FX500 6 Puck Clutch Kit 04-2015+ STi Part# 15-017-HDB6
CLICK TO VIEW Clutch Masters FX850 Twin Disc Clutch Kit 04-2015+ STi Part# 15-017-B-TD6
For those looking to push their car to the limit, and needing a clutch that can get them there, look no further. Clutch Masters offers the FX850 twin disc clutch kit for the STI. These units convert the clutch assembly from a pull-type design to a push-type for improved clutch actuation and pedal feel. If you are serious about motorsports, these setups are a must have.
The FX850 is for cars making from 600-1200hp and is a serious track clutch system. The setup is very similar to the FX700, but uses a larger surface area and different friction material for even more grip. The kit includes a billet aluminum cover, heat-treated diaphragm spring, billet aluminum flywheel complete with a replaceable steel friction insert, and throw out bearing.This kit has harsh, immediate on-off engagement and is recommended for race use only.
Amazing Prices on Driveshaft Shop Driveshafts!
Click Here to View Carbon Fiber Driveshaft
Only $894 including shipping in the lower 48 states! We will beat any price!
We will beat any price on Kartboy!
Click Here to View Kartboy Short Shifter Combo!
Go Fast Bits Shifters Include Reverse Lockout Press!
Click Here to View Go Fast Bits Shifter
SuperPro Drivetrain Bushings!
Don't be fooled by the cheaply made competition. SuperPro makes the highest quality drivetrain bushings in the world! Cygnus Performance is a SuperPro Master Distributor. We can get you the very best price on anything they make, and we have direct experience with all SuperPro STi parts! Find a better deal and we'll beat it!
CLICK TO VIEW Super Pro Differential Mount Bushing replacement 08-2015+ WRX & STi SPF3201K
CLICK TO VIEW Super Pro Differential Pinion Bracket Bushing replacement 08-2015+ WRX & STi SPF3200K
CLICK TO VIEW Super Pro Gearbox Cross Member Isolator mount 08-2015+ WRX and STi SPF3199K
CLICK TO VIEW Super Pro Pitch Stop 02-2015+ WRX & STi TRC3205
CLICK TO VIEW Super Pro Rear Diff Inserts 08-15+ STi/WRX/BRZ/FR-S Part# SPF4297K
CLICK TO VIEW Super Pro Shift Linkage Bushing 04-15+ STi SPF2462K
Click the Banner above to View our Injector Dynamics Catalog
Click the Banner above to View our GrimmSpeed Catalog
We can get anything GrimmSpeed makes and match any sales price 365 days of the year!
Click the Banner above to View our Whiteline Catalog
Thank you very much for taking the time to view our thread! This is just a small portion of our offerings. We can get most parts for your STi and BEAT almost any price! If you have questions about parts, if you need quotes or for us to beat a price or if you are looking for a part that you don't see on our website we are here to help. Please feel free to PM us, call us at 321-600-0889 or email [email protected] We look forward to hearing from you!
Thanks,
Geoff
1 - 20 of 97 Posts
